Question about Dryers
Whirlpool Duet gas dryer won't turn on
When I press the "On" button the dryer won't turn on. Sometime if I continue to push it, it eventually turns on and I can start the drying cycle. It doesn't matter how hard or soft I press it, if I open and close the door, or even if I switch to different setting, same results. HELP.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
It seems that the button is defective. This is something that will require a technician to check out.
Posted on Jan 24, 2013
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
SOURCE: Whirlpool Calypso Dryer Electrical Problem
Problem resolved. Although the membrane control panel passed the diagnostic test, it was defective. Probably a low voltage conductor went to ground, allowing the buttons to operate but throwing the control board into error mode.
Posted on Nov 11, 2007
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
john631068
  • 172 Answers
SOURCE: How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Posted on Nov 17, 2009
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
I have a whirlpool duet gas dryer that will not turn on. When I press the start button it makes a beep three times then the lights go off.
I had the same problem with mine. As it turned out the dryer door wasn't completely shut. You really have to push them hard when they are brand new and you should feel a second "click" when it pops in all the way.
Jun 12, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryers Logo
176 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
