Question about Crosley CW6000 Front Load Washer
Error code E8
Will not drain
  • Crosley Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Posted on Jan 24, 2013
Babylock rachel.... when I turn my stitch dial to 2 I get an e8 error, what does that mean my machine is brand new?
If it's brand new, take it back where you purchased it. It should be covered under store policy or warranty.
The manual usually describes error codes in the troubleshooting section. Or, you can search online:
Make + Model + the words "error code E8"
Nov 09, 2016 | Sewing Machines
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
What is error e8
Seems to be an water leekage in the machine. Look if there is water on the bottem plate.
Oct 20, 2014 | Bosch Washing Machines
WHAT DOES ERROR CODE E8 MEAN ON A FRONT LOAD WASHING MACHINE
Possible drainage problem, or control board failure. To check drain, disconnect the power cord from the receptacle, then remove drain hose from pump. Ensure there is no blockage in the pump nor in the hose. Reconnect hose and clamp. Reconnect power cord and check.
If still no good, suspect failed chinese control board.
Sep 26, 2014 | Crosley Washing Machines
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
Hp laserjet 1132 mfp e8 error code, how do i solve this
Hi Abu Bakarr.
The e8 error is refering to problems with the CIS Scanner. I have attached a link to the product service manual. Read page 122 about the e8 error and perform the 4 steps in the manual to fix the problem. If no luck, the CIS Scanner needs to be replaced. Good luck. http://www.feedroller.com/store/Service%20Manual/HP_LJ_M1130_M1210_Manual.pdf
Jan 10, 2014 | Canon PIXMA MP150 All-In-One InkJet...
Washing machine doesn't wash
E8 Means the temperature is too high. Replace the thermistor - temperature sensor, also known as NTC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2009 | Washing Machines
Needs simulations steps on how to reset a E8-000 code
Hello sir; This error code have no way to reset, the ptoblem is icu or pcu main board .
Apr 27, 2009 | Sharp AR-C150 Copier
Crosley CW6000 Front Load Washer Logo
135 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
