How to change the paper for fax sanyo sfx-11 - Office Equipment & Supplies
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: I don't know how to
Check for a dial tone with another phone plugged into the port on the fax.
Posted on Aug 31, 2008
  • 240 Answers
SOURCE: manual for sanyo fax machine model sfx-111,
(718)787-1301 call the above phone no and u ll get one i think its a authorised sanyo service centre
Posted on Jun 16, 2009
FixinFax
  • 3085 Answers
SOURCE: have a sanyo sfx 111 fax. cannot get the # key to
Put a DROP of alcohol or WD-40 on top of those keys and let it drip down into the key base. These 2 keys get sticky because they are seldom used.
Posted on Mar 02, 2010
  • 300 Answers
SOURCE: I have a SFX-11 fax
Stopping in the middle of receiving a fax and the display going blank is a good indication that the circuit stopped functioning.
Try dialing out and you should hear the beeps as you press the buttons.
Or ask somebody to call you to see if it rings or not.
The rest is obvious. :)
Posted on Apr 01, 2011
I have a SFX-11 fax machine. When I received a fax this morning and it stopped in half way. the screen shows nothing, but the handset (phone) is ok.
Apr 01, 2011 | Office Equipment & Supplies
I want to change the size of the paper from 81/2 x 11 to 11 x 14. I am unable to locate any tools that will let me do that. I am trying to create a 4 section brochure and want to use larger paper.
To make changes in the paper sizes , you have go to the "Printer Properties" to do that.
Go to "Printers & Faxes" -> Select the printer you are using, right-click and click properties to open the printer properties dialog box to make your paper sizes click OK.
Hope it helps.
Mar 11, 2011 | Broderbund Print Shop® 21 Pro Publisher...
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
Why does it spit out an extra blank page?
Set up needs to be changed . Its set to receive legal the long paper. You are useing standare lenth. Go to Paper tray set up. Get your manual out it will help you.( Good luck ) set to 8 one half wide and 11 in. long.
Jul 23, 2010 | Brother IntelliFAX 2800 Laser Fax
When sending fax on recievers end all the writing is downsized
Try sending a fax to someone else and see if it does the same thing.!
If your sending a 14" page to someone who only has 11" paper in the machine....the machine can only do one of 2 things...reduce the 14" page to fit on 11" paper "OR" print 11" on 1 page then the 3" on the second page....this setting is controlled by the rxing machine.
Apr 16, 2010 | Office Equipment & Supplies
Have a sanyo sfx 111 fax. cannot get the # key to work when I use the phone , aslo cannot get the flash key to work when I use the phone. help please
Mar 02, 2010 | Office Equipment & Supplies
Manual for sanyo fax machine model sfx-111, mechanical error, not feeding paper...
Jun 16, 2009 | Office Equipment & Supplies
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
ARM162
it is most likely Defaulting to that tray, you need to go in the menu and change the default tray to letter.
Aug 27, 2008 | Sharp Office Equipment & Supplies
66 people viewed this question
k24674
jasbo
jasbo
