Question about Splendide 2100 Vented Washer-Dryer
Noise dry cycle
Noise
  • Splendide Master
  • 17,129 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 24, 2013
How do i turn the volume down
There is no way to "turn down" the noise on any washer other than to balance the load of the washing machine tub as it spins. Typically the washer increases noise due to spinning during the rince and dry cycle. This noise is a consequence of the rapid spin rate needed to dry the clothes using centripetal acceleration and removing the water.
Feb 01, 2015 | Whirlpool duet Washing Machines
Fan is noisy intermittently well after wash is finished
It depends on what model you have. The fan is usually operating when the dry cycle is on. The dry cycle can be quite long compared to the actual wash (which ends when the rinse water is drained out). The dry cycle uses the steam in the dishwasher to circulate around the dishes. The fan keeps running until the full cycle is complete. If you are hearing heavy noises when the fan is running, then the bearing of the fan maybe damaged and you need to replace the fan.
Jan 02, 2014 | Fisher and Paykel Dishwashers
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
I have the duet whirlpool gas dryer - model #GGW9200LW1 and the barrel is making a lot of noise. It seems like one of the inside little cap is loose and the clothes aren't drying. Its taking too many...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Dec 29, 2010 | Dryers
In the middle of drying it stops and makes a noise like the cycle is finished and the cycle is not dry yet. Sometimes the dryer doesn't even go on at all. When pushed on it makes a noise like a horn.
Motor I am sorry to say is going bad. After it cools down you can start again for a short time and then the same thing happens again. A great dryer for the money are your Roper dryers sold at all Lowes. Very good dryer with an even greater price.
Jan 26, 2010 | Dryers
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Whirlpool Quiet Partner Doesn't finish cycle
FIX YA IS A JOKE I WOULD LIKE TO BURY THE ************** WHO CREATED IT!
Jul 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Splendide 2100 Vented Washer-Dryer Logo
35 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
isaac johny
isaac johny
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
