Cars & Trucks Logo
Posted on Jan 24, 2013
Where is the electric brake module located Lincoln Ls?
04 Lincoln Ls electric brake module 2c496
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jan 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
Helped
5858
Points
35
Under the dash . im not real sure i have no info . i will check . im just guesssing that its under the dash board .
5 Related Answers
Anonymous
  • 29 Answers
  • Posted on Nov 30, 2008
SOURCE: lINCOLN ls bRAKE lIGHT REPLACEMENT
One of 2 ways.......
#1) mounting screws on the exterior of the brake light lens.
#2) in the trunk behind the carpeting, usually this is the easiest way. either way the bulb is held in by a twist lock bulb holder.
GGBMDB
Anonymous
  • 235 Answers
  • Posted on Feb 19, 2009
SOURCE: 2002 LINCOLN LS V6 3.0 PCV VALVE LOCATION
it is down under the intake manifold. the intake manifold must be removed to get to it. this vehicle is known for developing a vacum leak in the elbow hose that connects to pcv valve, so ive done a few.
Anonymous
  • 145 Answers
  • Posted on Jan 13, 2010
SOURCE: battery location in 2002 lincoln ls
It is in the trunk under the carpet with the spare tire.
A
Anonymous
  • Posted on Mar 16, 2010
SOURCE: Replacing lincoln LS rear brake
Screw in rear caliper pistons. Install pads and caliper,then ratchet up parking brake by hand, at caliper. No electric or cable issues involved
A
Anonymous
  • Posted on May 23, 2010
SOURCE: where is fuse box located on 2001 lincoln ls...
You have fuses and relays-
Under the hood.pass side,front,next to washer bottle and ABS motor
On the right side kick panel,under glove box. Have to remove cover
In trunk,lift cover,left of battery.
2004 LINCOLN LS TRACTION CONTROL LIGHT FLASHING & ABS LIGHT ON & BRAKE LIGHT ON. DTC CODES B1342, C1730, C1998.
first check brake fluid level then you will have to test the wheel speed sensors that the codes refer to. when there is a sensor problem it will activate both the abs and traction control lights. the red brake light comes on when there is low fluid condition(leak),worn brakes that need servicing. also if there is a abs module problem it can set codes. you need to know what the codes mean this is a starting place to diagnoise.
How do i change the brake light switch on a 2000 lincoln ls
it is mounted to the brake pedal under the dash . it has a plunger that is in direct contact with the brake pedal arm. you'll see it
Can't get my car our of park its a 2000 Lincoln ls v6
When you operate the brakes, does the brake light come on?
If not, then check and/or replace your brake switch (located towards the top of the brake pedal).
If your brake light works, then check the gear shift lock solenoid operation. Check for power to the solenoid, when the brake pedal is depressed and check the solenoid movement. Replace if necessary.
4helpful
My 2005 Lincoln LS V6 has a message that says srvc P
The message means the electric park brake needs serviced. In this case I feel that considering the ac problem, the Coolant Control Valve is defective. The valve can create RF interference that messes with the electronics of the park brake system. The Coolant Control Valve is located at the right side bottom of the radiator fan shroud and has 3 heater hoses connected to it.
2answers
Where is the computer module on 2005 LS V6
its located on the right rear of engine compartment. happy hunting
5helpful
Traction conrtol , abs brake lights lincoln ls 2000
it might be a loose abs cable behind one of the brakes?
I have a lincoln ls 2000 brake light don't work
have you tried the fuse box located under the hood usually on passenger side fender well ?
2answers
Lincoln ls back brake lights dont work
If you have the owners manual for this car look in the index for fuses. This will give you specific location of which fuse protects the brake light. Fuse block is typically located under the drivers side dash, near the floor. Have you changed the bulbs?
4helpful
2answers
Replacing lincoln LS rear brake pads. How do you adjust the electric parking brake so the new pads will fit?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
