Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Water level How do I controll the water levels, also are there diffrent water levels or just one level. Water bill was huge just trying to check everything thank you.
  • 11,896 Answers
YOU CAN EITHER CONTROL THE LEVELS ON YOUR WASHER BY LOAD SIZE small=less water in the machine, or you can turn your water valves on clockwise
Posted on Jan 28, 2009
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
My Hoover Galaxy is not filling up,only the Hot water tap works.
sounds like the cold water intake valve has failed and will need replaced
its solinoid coil is prob open circuit
Dec 14, 2014 | Hoover Washing Machines
Water resevior is empty and light stays on?
If the high water level switch closes, the
compressor and condensor fan motors shut
off, and the water full indicator LED lights. The
water must be drained manually. Since you have dumped the water the high water level switch must be stuck in the off position. Page 42 of this manual shows the high and low water switch cover plate removed and the floats. Check the floats to see if something is making it stick or it has a hole in it. This manual is from WP but I imagine all of them type ACs come from the same source. PORTABLE AC SERVICE MANUAL
May 20, 2010 | Danby Portable Air Conditioner
Whirlpool lsr8233e - doesn't sense water level and water comes out of the washer. The must be a water sensor control of some type. Is there a diagram and part to replace.
Try checking the pressure switch it controls level of water by way of pressure switches off valves around the 3-5 psi mark..Think you may find that the hose feeding this is blocked by debris take off and clean 1st,You will see round can type switch with wires on and hose on it.....Check also the chamber feeding the hose @ drum level/
Mar 31, 2010 | Whirlpool LSR8233J
to maintain the water level there will be a level controler called like presostat in the IFB washing machine.and it function is after the water reaches the level this makes the solenoids (which will be called as electric water controler) to close the water line and to open the water line for please check these both the parts are working.
May 28, 2009 | LG WFT1071TP Top Load Washer
Whirlpool model awm293
the parts that control the water level is the water level's with a hose connected to tub and the water level switch. check if your hose is still ok, or your water level switch deffective
Jun 11, 2008 | Washing Machines
Kenmore 90 series top loader washer water level.
There are easy checks before you replace the level selector body
remove the trim plates at both ends of the control panel to expose Phillips head screws 1 at each end. remove the screws
lift and swing the control panel up and over the back, it is hinged at the top.
The washer can be operated in this condition for testing
1 Rremove the air hose, and blow it out.
often water remains in the tube after changing levels, the water is not compressible so a small change in water level in the tank, makes too much difference in the sensor.
reconnect the tube and try a cycle ~1/3 chance of fixing it
If fail,
2 The spring inside Kenmore water level sensors that reacts to air pressure in the tube is not up to the job and stretches, not noticeable till changing water level settings moves the anchor point of the spring.
pull off water level knob from control panel front, from control panel back depress lock tab at right of level selector body rotate counter clockwise 45 deg and remove
adjacent to selector knob shaft is 1/8inch nut, turn clockwise to raise water level counter-clockwise to lower water level, test, adjust, test adjust ~1/2chance of fixing it
If fail
replace level selector body
May 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 70 Series heavy duty washing machine
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Humidifier makes a huge noise and no mist
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
This next part may or may not be relevant.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly.
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
1835 Ferry Road
Naperville, Illinois 60563
Jan 28, 2008 | Crane Cow Humidifier
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
194 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
