Question about Empire DV-215 Direct Vent Natural Gas Heater
Empire floor furnace model 7077 backflash to orifice LP gas
  • 89 Answers
SOURCE: how to change the orfis from propane to gas on a empire 40,000btu
what is the model # for the furnace. You are going to have to change the pilot orofice and gas valve for natural gas also.
Posted on Nov 01, 2009
  • 12173 Answers
SOURCE: Empire Mod#UH-1250-1FSP Ser # K49789WR
need to notify empire their specs for their natural gas should have the answer the kit or conversion unit should have had the part -it might not need to be changed--but if it does info needed is size of heater btu's size of line what kit/gas valve unit ur using
Posted on Jan 25, 2010
SOURCE: I need a gas valve for this unit
Try empireheaterparts.com-------The new valve should come with a LP converson kit if not already installed.
Posted on Mar 19, 2010
SOURCE: Have an empire wall furnace. Natural gas. Vent
Not sure what the problem is, but mine does the same thing.It also blows the pilot light out when it does it..Had several service calls, no luck...POS, don't buy another Empire heater....
Posted on Sep 25, 2011
  • 2517 Answers
SOURCE: model 3572 empire floor furnace pilot goes out when turn valve to on
Clean pilot could be blocked or its the thermocouple needs replacing
Posted on Nov 26, 2012
Gas conversion lp kit 8927 has 2 pilot orifices...I only need 1, correct?
The smallest pilot orifice is used for LP. Make sure you read the instructions thoroughly. Usually the gas valve pressure regulator is disabled and the burner orifices are also changed. Good luck and hope this helps.
Aug 11, 2014 | Williams Wall Heaters: 30,000 Btu/hr...
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Empire wall furnace pushing down the pilot button trying to light the pilot found too much gas flowing
Is the button on the gas valve or a red button in the line to the pilot assembly? If its in the line, there is a regulator upstream of the button. If the gas is coming from the gas valve, there is a small screw covered hole in line with the pilot line in the gas valve. If neither of these apply, you may need to replace the orifice in the pilot assembly. Let me know how it goes.
Nov 19, 2013 | Empire Comfort Systems Direct-Vent Wall...
Model 3572 empire floor furnace pilot goes out when turn valve to on
Nov 25, 2012 | Empire Heating & Cooling
Have an empire wall furnace. Natural gas. Vent through the wall. My problem is that sometimes when it ignites, it makes a loud boom and I can see a flame flash at the top of the heat exchanger. I was...
Nov 09, 2010 | Empire Hight Efficient Direct Vent Wall...
Empire Mod#UH-1250-1FSP Ser # K49789WR Heater has been switched from LP gas to natural gas. I need proper orifice size to complete.
Jan 25, 2010 | Empire Heating & Cooling
How to change the orfis from propane to gas on a empire 40,000btu
Oct 30, 2009 | Empire Hight Efficient Direct Vent Wall...
Empire DV-215 Direct Vent Natural Gas Heater Logo
65 people viewed this question
Top Empire Heating & Cooling Experts
paulcarew
rudyjoe
Level 1 Expert
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
