Question about JVC AV-27230 27" TV
Hdmi setup for old jvc tv - JVC AV-27230 27" TV
    Top Expert:
  • JVC Master
  • 74,136 Answers
An HDMI to A/V converter must be used in between HDMI out device to this TV.
Posted on Jan 24, 2013
I have a JVC HD-70FH97 hooked to my digital box, via HDMI cable, and connected to the TV HDMI input 1. I cant get my surround system to work - any ideas what im doing wrong?
Check your HDMI audio settings. It may be trying to send a signal that is incorrect. How is the wiring setup? cable box to stereo, then to Tv?
Sep 21, 2016 | JVC HD-70FH97 70 in. HDTV Television
I can't get my xbox one to setup so I can play on my tv!
Hi Oreanna Corder, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
did you plug the hdmi cable into the left hand slot on back of x box one labelled hdmi out as there is also a HDMI in port . Please check and advise us
http://support.xbox.com/en-US/xbox-one/console/console-setup
Feb 12, 2016 | JVC HD-61Z456 Television
Cannot get home theatre to work with panasonic flat screen. Surround sound was working with old tv got a new one but now its not working. Do i need a different cable
your new tv probalby has an hdmi output. depeding on how old your jvc system is, iit may or may not have an hdmi input. not to worry, there should be some type of compatible output on the tv to send audio signal to the jvc. first look at the back of the jvc and see whats there. then look at the tv and you should see compatible output on tv and run proper cable to input on jvc. some auxillary audio outputs on the tv are driven by the volume of the tv itself, so make sure to turn the volume on the tv up a llittle to make sure its sending signal. you may have to go into the tv menu and turn the internal tv speakers off so you dont hear them and the jvc. its not a big deal if your hearing both, it just wont be true surrond sound. if it were mine, id turn the tv speakers off.
Dec 24, 2010 | JVC TH-C40 System
HDMI broken on JVC HD-56G786 TV
have you ever went thru your hdmi setup procedure that jvc recommends?
Sep 07, 2009 | JVC HD-56G786 56" Rear Projection HDTV
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Ps3 connection to jvc tv
Is the tv an lcd or a crt? and how are you connecting it with composite (red white and yellow) component (red blue green white red) or hdmi? if through composite or component is the ps3 set on the right connection? if through hdmi is your tv HDCP compliant? if not than it prob won't work till you do the firmware updates on your ps3 via a broadband connection. if it still does not work than you won't be able to connect it to that tv only to a tv (and surprise surpirse all sony lcds are HDCP compliant) that is HDCP. it normally says in the instruction manual. Unfortunatly HDMI connection is not the godsend they said it would be. if the device does not immediatly talk to what you are pluggin it into than you are going to have problems
Mar 08, 2008 | JVC LT-37X776 37 in. LCD HDTV
Hdmi Issue
Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
JVC AV-27230 27" TV Logo
44 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
