Question about AcuRite Acu-Rite 00593W Wireless Weather Station
Why is the outside temperature not displaying on the base?
The outside temperature is not displaying on the base--I replaced the batteries, but there is still no play.
  • Lynn Pharr Jan 24, 2013
    Oops...I meant to write display rather than play
    Thanks Tom!! I do believe that solved the problem :)
    Top Expert:
  • AcuRite Master
  • 41,769 Answers
After a battery replacement, the outside and inside units have to "talk" to each other before you can get a display. Also, the outside unit's batteries have to be replaced first. You should not press any buttons for 10 minutes until the two units have finished "talking"
Posted on Jan 24, 2013
    Thanks Tom...I believe that solved the problem :)
I have a weather station 9N14 V030U and I can't get the outside temperature to program. We just changed the batteries in both units.
  • Remove all batteries
  • Install replacement batteries in the outside unit
  • After allowing time for the outside unit to initialize and begin transmitting data, install batteries in the inside unit. You should see the outside temperature displayed.
May 28, 2017 | Measuring Tools & Sensors
Why is my outside temp not registering. I have replaced the batteries
  • Install outside batteries
  • Move from outside to inside at a casual pace to allow time for outside unit to begin sending temperature
  • Install inside batteries. You should see outside temperature displayed
I find that outside temperature display comes and goes depending upon the weather, e.g., Today at 12 pm, the outside temperature is 35 deg F; earlier this morning it was - -. For the last couple of days, the temperature has been - - then suddenly last night it was 28 deg F.
Jan 30, 2017 | Measuring Tools & Sensors
Why is indoor display not showing outside temperatures?
If the condition comes and goes, the outside unit may be exposed to extreme temperatures or the batteries may be too weak. If the condition occurred after battery replacement, remove all batteries then reinstall the outside battery and wait for it to "initialize" and begin sending data. ReInstall the inside battery and you should see the outside temperature displayed.
Feb 13, 2016 | Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 05, 2016 | Taylor Measuring Tools & Sensors
Will not display outside temperature even though I changed the battery on both the inside and outside unit
Find reset pin hole on base unit. Push in with a paper clip. Pin hole may be in battery compartment.
Mar 13, 2015 | La Crosse Technology TX37U-IT 915MHz...
I am unable to get the remote temperature to show on the base unit. It appears that there is no signal.
In general, batteries are installed in the remote transmitter first and time is allowed for the transmitter to begin sending data. Batteries are installed in the receiver next and you should see the outside temperature displayed.
Dec 25, 2014 | Measuring Tools & Sensors
Outside temp
Remove all batteries. Reinstall batteries (or new ones) in the outside unit. Install batteries in the console. DO NOT TOUCH ANYTHING! Wait until the outside temperature displays on the console. Make any adjustments necessary.
Nov 05, 2013 | Davis Instruments Davis Vantage Vue...
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
AcuRite Acu-Rite 00593W Wireless Weather Station Logo
775 people viewed this question
Top AcuRite Measuring Tools & Sensors Experts
Tom Chichester
Are you an AcuRite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
