Lenovo keyboard ku 0989 calculator key doesn't work
Calculator key doesn't work
4 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: "ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Posted on Jun 19, 2011
  • 8064 Answers
SOURCE: my calculator casio fx-350ES doesn't
Not all calculators have that. The Fx115ES and the FX991 ES have a lot more options thatn the FX300Es and FX350ES. I believe you only have COMP (general computational mode), Table and STAT.
Why? It was not designed that way.
Posted on Aug 19, 2011
elix0411
  • 3530 Answers
SOURCE: function keys directly not working
Welcome to Fixya
You need to enable it at the Bios. Reboot the computer and press the button that will lead you to the BIOS menu of the motherboard. Go to System configuration and go to actions keys mode. Press enter then select "ENABLED". Save settings before you exit then test the issue.
Thank you for using Fixya!
Posted on Sep 08, 2011
Why doesn't my print screen button work?
Hi
The PrtSc (Print Screen) key when pressed will seem to do nothing but it does when you hit the key it puts a copy of your current screen to the clipboard.
To prove this do as below
1 press the Prtsc button on your desktop
2 Load paint and choose new
3 go to the paste option or press CTRL+V and you should get a copy of your desktop in paint.
Cliff Cook
MCP
Jun 16, 2014 | Lenovo ThinkCentre Computers & Internet
Need a manual for leveno model # KU 1153
http://support.lenovo.com/us/en/downloads/ds018386
May 28, 2014 | Logitech Cordless Desktop EX110
This is a setting you may have to change on your computer and not the keyboard. Reboot your machine and enter your BIOS (sometimes called Setup) there is usually text in the corner of your screen when you first turn on your computer that says "Press F2 for setup" If not, google how to get in. Once there, you need to find the setting for F Lock (depending on your computer, it may be called ActionKeys, who knows -- you can google that first) and change that setting. Sometimes you have to enable it and sometime you have to disable it. Either way, the F Lock will be toggled and the F Keys should function normally and you'll have to press the Fn key to get Mute.
Apr 30, 2014 | Computers & Internet
The Ctrl key don't work
Chances are the keyboard is dirty - pull the key off and clean it - but there are two so if it is bugging you replace the keyboard if cleaning doesn't work
Jan 11, 2013 | FireFly Borealis KU-0533 Keyboard
Keyboard doesn't work
Get your laptop's keyboard replaced .
Jan 02, 2013 | Lenovo IdeaPad S10-3 Laptop
HP 3G reset
Press and hold the ON and the top-row-third-key-from-the-left keys simultaneously, and then release them.If that doesn't do it, press and hold the ON, top-row-leftmost, and top-row-right-most keys simultaneously, and then release them.It that doesn't do it, turn the calculator over. Straighten a paper clip and poke it into the small hole below the bump (upper-right). Hold it there for a second and then remove. (You may have to do one or both of the keyboard steps above as well).
Apr 09, 2012 | HP 38G Calculator
DISABLE FN KEYS IN KU-0989
Download de software driver below:
https://mega.co.nz/#!kEo0EBAC!bMd396-dH_U2xWhofCnwVDdA3WF5SGYc0Qma7t2dipQ
After, open "Lenovo Slim USB Keyboard" software, and check box to standard function keys, uncheck to special function keys.
Jan 29, 2012 | Computers & Internet
Lenove ku-0989 fn key
  1. Numerous folks indicate that Windows doesn't register the Fn key as a keypress but using a tool that gives the ASCII value of a keypress I see the Fn key returning FF (perhaps FF in this case means 'not registered'). I also see that keys like Ctrl register with one ASCII code when pressed alone and another when pressed in combo with another key. Fn will only register when pressed alone, so Windows definitely isn't seeing the combo. This took a solution like AutoHotKey off the table.
  2. I ran KeyTweak (which shows you the hardware scan codes of a keypress and the Fn key registerd as 57443). Using this program I remapped Fn to the Ctrl key; this worked perfectly. However, I suspect that because of the issue in #1, the combo of, for example, Fn + C did not execute a copy.
Nov 22, 2011 | Lenovo Keyboard
Function keys directly not working (working only after pressing Fn key button).How to open function keys F1 to F10 directly and calculator is not open. Please help me. Our Keyboard MODEL: LENOVO KU-0989
Welcome to Fixya
Sep 06, 2011 | Lenovo Keyboard
My HP KU-0841 keyboard has suddenly stopped working, it is only a couple of weeks old, it was fine up until yesterday. I have tried it with other computers /laptops and it doesn't work with these...
If it is only several weeks old, it should still be covered by warranty, and therefore you should be able to exchange it for a working one.
May 25, 2011 | HP DC170B Keyboard
52 people viewed this question
k24674
jasbo
jasbo
