Question about Health & Beauty
Iq massager will not take a charge assume need to replace battery
Having problem recharging battery. assume need to replace battery but do not have instructions in current documentation. bought summer 2011 and have not charged it in months
SOURCE: Trimmer Not Charging - No CHARGE Light too.
I have the same problem using Remington MB 200
Posted on Apr 11, 2008
SOURCE: peg-perego quad 12v. Just bought it, no instructions, need to charge battery can't find where to plug charger in.
It's in the front. the bumpber pulls down and the plug is behind it.
Posted on Dec 17, 2008
  • 43 Answers
SOURCE: Battery will not charge
Power reset the unit, unplug it pop out the battery and hold the power down for a minute, put the battery and ac adapter back in and start her up, the mobo was probably still holding power when the battery died causing a "hiccup"in the system, this should resolve or at least help a little
Posted on Jan 24, 2009
SOURCE: You didn't have GW510A (limited edition) Assume this is similar?
It's a common problem, now that the earlier Tough Solar watches are getting on in years. Plus, there was apparently a bad production run by the battery manufacturer (Matsushita/Panasonic), so there's a certain subpopulation of G-Shocks that are seeing premature failure.
Replacement is easy. You'll need a jeweler's screwdriver set, ideally some plastic tweezers (though a toothpick will do), some metal tweezers for one of the final steps (but not for handling the battery), and if you're smart some latex gloves to keep everything pristine. Get a little tube of silicone grease, too (and ONLY silicone). Careful with it, though-- it's impossible to wash off of clothing, etc.
It's all proceed-at-your-own-risk, of course, but good instructions are posted at http://forums.watchuseek.com/showthread.php?t=41076
Mind the little springs, and note which one came from where.
Altogether, it's an easy job. Good luck!
Posted on Apr 09, 2009
Cytherian
  • 109 Answers
SOURCE: My Braun 7526 razor will
This happened to me as well. Often the batteries will last longer than the rest of the shaver. You can obtain the batteries as cheaply as $12 a piece on "that auction site."
Opening a Braun 7000 Series Shaver
1) Find a thin metal object with no sharp edges (such as a nail file). Use your thumb and pull on the bottom end cord socket part, enough to cause a gap between it and the back shell. Insert the metal object into the gap in the center of the part. THEN pry it off. If you use a regular screw driver, you will likely cause gouges in the plastic. And the best leverage is in the center.
2) The silver side parts are held on by two tabs at the top. With the bottom piece gone, the side parts swing off easily. Don't worry about keeping track of which sides the silver trim pieces go on, as they're designed to fit on only one side (you'll see the cutout for the shaver head stem is off to one side).
3) The case is held together by 4 small torq screws. Use a torq screwdriver--do not attempt to do this with anything else. Be careful to turn the screws slowly, so you don't strip them.
4) With the screws removed, the two halves of the shaver will come apart. The remaining parts can be extracted without any special tools. Keep note of how they are removed, as assembly will be the reversal of removal.
5) Note that if you are replacing the batteries (there are two of them), you will need a soldering iron to detach them from the circuit board, unless you're replacing the whole part.
6) Reassembly is pretty much what you expect--the reverse of disassembly. However, the bottom cord socket part is tricky to get put into place. Pushing straight down on this part will not get it to go in, nor any other obvious way. It's best to get the prongs inserted on one side, then while pushing in on the prongs of the opposite side, apply pressure on the top side surfaces. The part should snap right back into place.
Posted on May 23, 2009
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
Iq massager professional battery replacement
then your charger or cable or connections are bad,the internal battery isnt replaceable, https://tensunitmassagers.com/catalogsearch/result/?q=lithium+battery
Jan 24, 2013 | Health & Beauty
How much time should a iQ sound mp3 player charge
MY IQ SOUND MP3 ONLY STAYS CHARGED FOR 5MINS,I PLUG IT IN TO CHARGE AND INSTANTLY IT SAY BATTERY FULL BUT ONLY LAST AGAIN 5MINS,ANY IDEAS.
Dec 05, 2010 | Bell Technology IQ Sound SC-2528 MP3...
Hand held rechargable masager recharges but doesn't not vibrate when the button is pressed, the red light does not turn on either. The red light only goes on when it's recharging
Possible that the supply to the motor is cut or the motor is faulty or the switch has failed.
you have to remove and check the three possible faults, perhaps inthe process of vibration this can make wires break off contacts.
Sep 21, 2010 | Homedics Rc Quad Quad Extreme Rechargeable...
I just charged my camera's batteries and an error
Your camera is telling you that the batteries have insufficient power. First thing to check is that the battery contacts on both the batteries and inside the camera are bright, clean and free of grease or oil.
Assuming that you're using the original NiMH rechargeable batteries which came with the camera, then you almost certainly need to replace them with new ones as they cannot be reused indefinitely.
To test whether the problem is with your rechargeables or with your camera is very easy. Just buy a set good quality, non rechargeable, alkaline (e.g. Duracell) AA batteries. If the problem disappears then you know that you need to buy new rechargeable NiMH batteries next time.
There is also a small possibility that you have a faulty recharger but it's unlikely. The only way to test it without special tools is to try getting your NiMH batteries charged in a borrowed recharger. If the batteries get fully charged then the error message on your camera will vanish and you'll need to buy a new recharger. Just make sure that the charger is designed for NiMH though or you will damage your batteries and possibly the charger.
Jan 15, 2010 | Canon PowerShot A560 Digital Camera
HOW LONG DO i RECHARGE FOR.
Did you let it fully charge before you started using it? Most companies will tell you with any electrical things you need to fully charge before using. To fully charge it can take any where from 4 to 24 hours. So place it on the charger for a full 24 hours then see how it works. Then if it still doesn't work it may be defected.
~~~Good Luck~~~
May 22, 2009 | Wahl 2 Speed Hand Held All Body Massager...
Need a battery replacement battery for cordless theraspa turbo.
Has anyone been able to find out if these Brookstone massagers can have the old batteries removed & replaced?
They stopped selling this model a while ago.
Feb 26, 2009 | Brookstone Theraspa Turbo Massager
Brookstone acuvibe soft touch massager
The current unit sold by Brookstone does not have a power cord. The unit is sealed and the battery is not replaceable. Many units eventually quit working when recharging cycle quits. Only solution is to replace the unit or contact Brookstone for their service center. Probably cheaper to replace the unit.
Nov 04, 2008 | Interactive Health Acuvibe Soft Touch...
Battery charge
The charging time is different between every product and product. Usually, the standard charging time is 5 hours (full charge). A full charge will give youabout 40 minutes of cordless use.
Aug 27, 2008 | Allegro Lomi Lomi Personal Massager
Health & Beauty Logo
389 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
