Question about Polaris Winter Sports
Lights not working on Polaris snowmobile
Headlight and tail light not working, brake light works
SOURCE: no headlight or tail lights
my tail lights on a 2002 buick regal do not go on when lights are on, I changed a couple of the bulbs still nothing, brakes lights and backup lights work.... also the inside dash lights do not work could it be a related problem,
DDennis
Posted on Oct 17, 2008
  • 125 Answers
SOURCE: headlights work but dash and tail lights dnt
look for the relay for the parking light
Posted on Apr 30, 2009
  • 12 Answers
SOURCE: 2003 polaris 550 trail touring,revearse not working
the high idle could be a dirty needle check your carbs i have that problem with my 550 rmk the reverse light could be your wire harness check your wires with any wire tester idk the specs for it but also clean your connections with some electrical wire component cleaner and use so di-electrical grease if all else fails you may need to bring it to a mechanic for a small fix like that it should run up that high
Posted on Aug 14, 2009
  • 75 Answers
SOURCE: 1991 Toyota Camry, tail lights and dash lights don't work
Have you looked under the hood? There are more fuses under the hood. Is your dimmer turned down on your dash lights?
Posted on Jan 26, 2010
  • 35 Answers
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Posted on Feb 17, 2010
Headlights and hand warmer stop working cannot find any fuses
NO headlights, guages, handwarmers!!!! - REV Chassis - Performance ...
www.dootalk.com/forums/.../432565-no-headlights-guages-handwarmer...
Jan 8, 2011 - My hand warmer Stopped working yesterday all of a sudden and it was a bad ground. Not to familiar with electrical but might be a start.Missing: snowboarding
My snowmobile stopped producing electricity for the light ...
https://answers.yahoo.com/question/index?qid...
Jan 11, 2010 - Runs perfect, but lights went dim, handwarmers were not reallyworking. Digital display would only work if hand-warmers were turned off.
1999 Polaris Indy 500 blown headlights & electrical issues ...
www.snowmobileforum.com/.../58812-1999-polaris-indy-500-blown-he...
Feb 2, 2011 - First off the headlights/tail light got extremely bright and blew. ... also thehand warmers stopped working then the rubber melted. codyc95 is ...
Amazon.com: Customer Reviews: Zippo Silver Hand
Jan 14, 2016 | Winter Sports
Head/rear lights don't work.. But dash/hand warmers/brake light works
No Dash lights, tail lights or Marker lights But Headlights, brake ...
forum.ih8mud.com > Forums > Toyota Tech Forums > 80-Series Tech
Dec 6, 2014 - Now my taillights don't work but Brake lights, Turn signals are good. .... If all the fuses check good with a meter, then head upstream to the ...
Thread: Tail Lights won't work..Brakes,Blinkers,Reverse does ...
www.expeditionportal.com > ... > Toyota: FJ, Hilux, Tacoma, 4Runner
Jan 16, 2014 - 10 posts - ‎4 authors
My bulbs are fine, because the blinkers work, the brake lights work, and so do the reverse, but no tail lights ... I know that the "License Plate" lights are on the same fuse as the tail lights. ... However, I don't have a schematic, so I don't know if that's the case. ... Anywhere I roam where I lay my head is home.
Rear Lights May Not Work Due to Rear Light Socket Plate ...
repairpal.com > Problems > Oldsmobile > Silhouette
Tail lights don't work right. ... I would suggest if you can replace the heads of there bad then do all at once because of you ... Replaced bulbs but still don't work. ... What would make my rear brake lights not to work and also my traction part also.
Dash lights and running lights not working after installing ...
? 1:25
https://www.youtube.com/watch?v=SK36wPXo2EQ
Feb 11, 2014 - Uploaded by 4Runner Nation
I got the same problem with my 91 f150 but just the dash lights don't ... for my head lights n dashlights ...
turn signals, head lamps, tail lamps, auto dome li
Jan 13, 2016 | Saddlemen SNOWMOBILE REPLACEMENT SEAT...
Headlights work fine. Why are all gauges/ electronic dash out?
Electrical issue - no headlights, tach, etc - HCS Snowmobile Forums
www.hardcoresledder.com > ... > REV Chassis
Feb 2, 2009 - 12 posts - ‎2 authors
There is no voltage at the harness with the relay at all. ... Previous Sled(s): 09 f1k SP,07 f8 SP,fusion 600@900 ... We havea 2006 600sdi and everything works but the headlights. ... relay is good, But this just happend to me sled starts and runs fine ... As soon as I rev it up the dash, tach, headlamp go out.Missing: 600headlights ‎electronic
06 fusion 600 bad volt regulater [Archive] - JohnDee.com ...
www.johndee.com > ... > Discussion Board > Tech Talk
John Dee
79 posts - ‎8 authors
I believe I have a bad voltage regulator going out on my sled. lights are diming and ...I'm under the impression that polaris has replace the old regulator with a new ... They are way down under the oil tank, brake, and all that stuff, up tight ... While riding, my sled had dim lights, no hand warmers, gauges would go in and out.Missing: 600headlights ‎electronic
Polaris Fusion 600 HO LED tail lights - YouTube
? 0:31
https://www.youtube.com/watch?v=oG2BWF4xVKg
Sep 28, 2011 - Uploaded by Trent Robinson
Most Fusion 600 HO owners at some point have issues with their ... This makes sense but the electrical system is AC on this sled AND people complain of the brake indicator on the dash stays onall of the time. ... Not sure on the indicator, mine works fine. ...2006 Polaris Fusion 900 that we are parting out.Missing: 600headlights ‎gauges ‎electronic
battery light blinking with full battery - TrackShare.com
www.trackshare.com/forum/showthread.php?t=32645
Jan 01, 2016 | Polaris 2006 Fusion 600 HO
With headlights off, tail lights and brake lights work. With headlights on, tail lights work. But only one brake light works (drivers side). Why doesn't passenger side brake light work?
Replace the right rear brake light bulb. It is possible that the filament has burnt out and has fallen across to rest on the brake light filament. This would cause the condition you are experiencing.
Sep 01, 2015 | Cars & Trucks
Polaris snowmobile troubleshooting
Well Cindy let me ask you was it doing it since you got it ? or it just start doing this ? just so you keep in mind that since you dont have battery in idle can be less power into the bulb filament now when accelerate creating more power meaning more light on bulb...
Jan 03, 2014 | ATVs
2002 polaris 700 xc tail light
breakdown the wireing using a 9v bettry see in which of the wire u get the lights on
Dec 04, 2013 | Polaris New Genuine Polaris Snowmobile...
1994 dodge dakota my headlights and tail lights and brake lights don't work my abs and parking brake lights are on my dash lights don't work either I replaced the headlight switch and still no
These are all different circuits. The brake lights are on a 10amp fuse - the headlights are on a 50amp fuse - and the parking and dash lights are on a 20amp fuse.
Do you have power going into the headlight switch and the brake light switch ?
Jan 29, 2013 | Cars & Trucks
Anyone know about 1996 polaris sportsman 400 - none of the lights are working - headlights, tail lights, not even the neutral light or reverse lights work - have looked for for broken wires and can not...
I also have a 96 Sportsman 400...local dealer told me if these bikes are operated with a low\bad battery the electrical system is designed such that the light bulbs will blow. I and a bad battery and non of my lights worked when I got the bike started. So, I replaced the battery and headlight bulbs and they now work. I would recommend replacing your battery if it's questionable and then your bulbs...worked for me!
Nov 08, 2010 | Polaris ATV
Head light and tail dims when idleing and driving on my 1995 polaris 600 triple xlt
Lighting coil is bad. Take off flywheel and replace the lighting coil. Should solve your problem.
Dec 15, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
262 people viewed this question
Top Polaris Winter Sports Experts
Todd Arndt
Todd Arndt
Lawrence Oravetz
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
