Question about Lexmark Z2420 Printer
Cartridge problem Everytime I attempt to print my printer says 1. the printer is busy 2. cartridge problem. Under the heading "cartridge problem" the printer gives me instructions on what to do which are, 1. turn the printer off 2. open the cover 3. turn the printer on 4. remove both cartridges 5. reinsert both cartridges 6. close the cover 7. retry your print job. I have done these things several times in every variation. I am using a different computer than I used to do this on and I am having the same exact problem. Please help.
    Genius:
  • 1,669 Answers
Sometimes the cartridges are just plain defective, no matter how much they cost. save yourself some grief and just replace both of them and see what happens.
Posted on Jan 24, 2013
WhiteFox4
  • 641 Answers
SOURCE: MY PRINTER (Lexmark X2400 series printer)
Windows 98, is your operating system, thank you for clearing that up. Windows 98 is very unstable and the most hacked operating system in the hacker community. I recommend trying Ubuntu. Download for free and burn it to a CD-R and reboot to try it. You can always install it later if you enjoy it. It's simple to learn because of the new GUI. Most drivers are automatically configured and I think your printer is supported for Linux (ubuntu).
Posted on Jan 02, 2010
don_farr
  • 1018 Answers
SOURCE: I replaced the color cartridge. I aligned it. I
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Feb 15, 2010
  • 492 Answers
SOURCE: after changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Posted on Jan 23, 2011
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: My printer error message indicates-
    Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
    Posted on May 03, 2011
    printmastert
    • 3344 Answers
      Verified Fixya Pro
      SOURCE: I just put a new black ink cartridge into my
      Make sure you are inserting the correct version of black cartridge for your model. Try to remove both cartridges from the printer. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert your cartridges. You can also try to insert a different known working black cartridge to determine if the other is faulty.
      Posted on Jun 30, 2011
      Have error code print unable 51 what do I do to clear?
      Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
      (1) Open the printer
      (2) Remove the ink cartridges from the print head.
      (3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
      (4) Repeat this until there is no ink residue coming off on the cotton swab.
      (5) Once finished, allow to dry and replace the cartridges
      (6) Try to print something now
      If that does not work then you have one of two possibilities:
      (1) One of the ink cartridges is defective and causing the error
      (2) If it's definitely not that, then the print head will need to be replaced.
      Nov 10, 2016 | Brother MFC-5460CN InkJet Printer
      What is error B200 when attempting to power up
      http://www.printerdiary.com/2011/09/canon-error-b200-how-to-fix-it.html
      Error B200 on Canon printers is a print head error. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
      (1) Open the printer and wait for the carriage to slide over
      (3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
      Mar 24, 2012 | Office Equipment & Supplies
      My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
      May 26, 2011 | Brother Office Equipment & Supplies
      Print output is coming out fuzzy.
      Let me know,if needed further assistance.
      Hope i helped you.
      Thanks for using ' Fixya ' and have a nice day!!
      May 04, 2011 | Brother MFC 420CN All-In-One InkJet...
      How do i clean the heads on my lexmark x4580 printer the black is not printing but the colour is ok and the cartridge is full of ink cheers
      • Hello,
      • Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
      • (1) Open the printer and wait for the carriage to slide over
      • (2) Remove the ink cartridges from the print head.
      • (3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head and the electronic contacts on each ink cartridge.
      • (4) Repeat this until there is no ink residue coming off on the cotton swab.
      • (5) Once finished, allow to dry and replace the cartridges
      • (6) Try to print something now
      • If that does not work then you have one of two possibilities:
      • (1) One of the ink cartridges is defective and causing the error
      • (2) If it's definitely not that, then the print head will need to be replaced.
      • Thanks
      Mar 10, 2011 | Office Equipment & Supplies
      Unable to print 36
      1. Remove print cartridge.
      2. Use cotton swabs dipped in hot water to clean the print head.
      3. Repeat until there is no residue coming off of the print head.
      4. Allow it time to dry.
      5. Place the print cartridge firmly back into the printer and attempt to print.
      Mar 02, 2011 | Brother MFC-6890CDW Printer
      I have a full black ink cartridge in my printer and have executed the deep cleaning many times, but my black ink will not print.
      Since it looks like you have try deep cleaning, I would say you need an print head.
      Here is canon info.
      Issue: Black ink does not print
      Solution: The Print Head may need replacing - iP6000D
      Replacing the print head
      The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
      • The nozzle test appears broken or to have horizontal white streaks.
      • One or more of the colors is missing from the Nozzle Test.
      • The colors are incorrect on the Nozzle Test.
      • A print head error is indicated on the unit.
      • The printer powers off when the print head is installed.
      If your printer is still under warranty :
      For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
      If your printer is no longer under warranty :
      • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays). Pay for support is required on all units outside their original warranty, unless covered by a Canon Extended Service Plan. If it is determined that the problem you are experiencing is due to a failure of the printer's hardware, the pay for support charge will be canceled. If your out of warranty printer is determined to have a hardware problem, you have the option to purchase, at discounted pricing and free next business day shipping , a new or refurbished product from our current product line, which includes units with Canon?s new ChromaLife inks, PIXMA Technology, and a limited manufacturer?s warranty.
      • You may purchase a print head* by calling 1 (800) OK-CANON (1-800-652-2666) between 8:00 a.m. and 12:00 a.m. midnight, ET, Monday through Sunday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP6000D) and part number (QY6-0050-000) ready for the sales person.
      Feb 23, 2010 | Canon Pixma iP6000D InkJet Photo Printer
      My HP Business Inkjet 1200 printer always prints
      Some of print heads may be failed.First clean very well the contacts on the print heads and printer using piece of cotton and some alcohol.If not help look which color don't print and replace that print head.
      Nov 16, 2009 | HP Inkjet 1200dn Printer
      Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
      View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
      go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
      Then go to page 62 and allign the print head automaticly following the instructions it gives.
      This will re-callibrate the ink level on the printer and should read correctly for you.
      Thanks
      CompuFirm
      May 27, 2009 | HP Business InkJet 2800 Printer
      Lexmark Z2420 Printer Logo
      47 people viewed this question
      Top Lexmark Office Equipment & Supplies Experts
      Don  Farrell
      Don Farrell
      Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
