Question about Pass & Seymour #696LAGCC6 15A Almond 3WY Switch
696 series pass an seymour switch, can you use a three way switch like a standard switch? and what does removable tab do.
After wiring it turned on ceiling fan in other room and other things. will the removable tab removal help make this a straight up light switch with two switches on it stacked on top of each other. three screws on one side two on other and a ground wire coming from back.
How to troubleshoot the installation of a Pass & Seymour three way switch
Standard 3way switch. You have two matching colored screws. they are the travelers. The odd colored screw is either power in or switch leg out depending on which end of the line you are on.
Jun 03, 2014 | Pass & Seymour Trademaster TM873WCC10...
Vanity cabinet with lights needs power
Dimmer wires in series on either wire of the cord.
Nov 27, 2013 | Pass & Seymour Pass Seymour 90611WV 600W...
How do you remove tab on pass & seymour 696 switch and what does it do
The tab will snap off by grabbing it with needle node pliers. the tab is for a common feed to both the 3way and single pole switches.
Jan 23, 2013 | Pass & Seymour Electrical Supplies
Have a d703 dimmer switch, trying to hook it up to a three way switch. electical outlet has a pass & seymour switch which has a red and blk connected on both sides of the switch and the whites tied...
If you had four wires, and your dimmer only has three, then it's not going to work. Your existing switch is often called a 4-way (in the US anyway). It is used in between two or more other three way switches. If you have only two switches, they can both be 3 ways (using only three wires). Additional switches have to be 4-ways (using four wires). An option is to use your dimmer at the first or last switch location. But if you want the dimmer at your chosen location, you need a 4-way dimmer. By the way, you can use a 4-way switch in a 3-way situation, by not using one of the terminals on the switch. Please vote if you found this helpful good luck Al K
Dec 14, 2010 | Pass & Seymour #R600PLAV 600W Almond SP...
Need a wiring diagram for 696 seriess switch
You don't need a wiring diagram.
The screws tell the story.
On one side of device has 2 screws.
On other side has 2 screws.
Green screw is for bare ground wire.
1) One side will have dark screws and the other side will have brass screws. The dark screws will be connected together with a brass plate. The brass screws will be separate.
-or-
2) One side will have brass screws and the other side will have silver screws. The brass screws will be connected together with a brass plate. The silver screws will be separate.
#1 Hot from breaker connects to dark screw. Wires to Load (light,fan) connect to brass screws.
-or-
#2 Hot from breaker connects to brass screw. Wires to Load (light, fan) connect to silver screws.
Nov 08, 2010 | Pass & Seymour #696LAGCC6 15A Almond 3WY...
Is there a wiring guide for the Pass and Seymour LSDC163PWV? Which colors are for the Fan control and which for the Light?
Go to the website below for diagram. Under specifications.
https://www.legrand.us/passandseymour/fan-controls/de-hummer/ls-series/lsdc163pwv.aspx
Jul 03, 2010 | Pass & Seymour Pass and Seymour Decorator...
I bought a Dual fan and light control SLSDC16WCC6, no instructions in the box. The unit has red, black, yellow, and green wires. The electrical box for the wall switch has three wires, orange black and...
Would suggest you contact the Pass and Seymour Div. of Legrand (France) and ask for the pdf file with the instructions. Your unit has a wireless function and must be work properly.
Sep 02, 2017 | Pass & Seymour CS320LACC 3-WAY COMMERCIAL...
Pass & Seymour #696LAGCC6 15A Almond 3WY Switch Logo
83 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
Mike Squire
Mike
Gil Shultz
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
