Question about Linksys WCG200 Wireless Cable Modem 54G Gateway with 4 Port Switch Router (NETWLSWCG200)
Conflict between wireless router and cordless phone
When ever i use the phone, it kicks me off the internet, my phone is a ge 2.4 ghz, do i need to reconfigure?
  • Michael Ward May 11, 2010
    What kind of internet acess do you have? Who is your ISP? How old is your router? How old is you phone? Is there a filter between the wall jack and the phone?
  • 34 Answers
you should try changing your wireless channel in the router setup.
1) log into your router.
2) go to the wireless setup page.
3) change the 'Wireless Channel' from auto to 1-11.
4) re-boot your router and re-connect to it.
5) use your cordless phone and see if the connection drops out.
6) repeat steps until you have a stable channel
good luck :)
Posted on Jan 29, 2009
  • Tekmekanik
    Tekmekanik Jan 29, 2009
    Just to clarify, your cordless phone and wireless router are operating on the same 2.4GHZ frequency band; which is split into channels i hope you can find a router channel that will work. If not you might try changing the location of your phone base or router further from each other.
Will your internet box interfear with a cordless phone if they are to close together ?
A wireless router and wireless network adapters can have interference issues with cordless phones. It depends on the network adapter frequency and the cordless phone's frequency. Most problems will occur with a phone that uses 2.4GHz. This frequency will interfere with 802.11b/g networks and single-band 802.11n wireless signals.
A DECT cordless phone operates at a different frequency from the 802.11g and 802.11n single-band and will not interfere with a wi-fi network with those modes.
However, some routers and wireless adapters can use the 5GHz range (802.11n and 802.11ac, among them). These can have a problem with cordless phones that use 5.8GHz. However, there is a simple solution to avoid much of the interference at 5GHz. First determine the frequency range of your phone by getting the FCC ID from the base of the phone. Then use Google or another search engine to find "FCC ID Search Form". It has been at http://transition.fcc.gov/oet/ea/fccid/ in the past. The first three characters are the Grantee ID for the search form. The rest is the product ID. Look for the SAR report for the phone and then (probably on the second page) find the TX frequency range and the Max RF output power tested. Now go to the wireless router's setting page and make sure that it is using channels that do not use the same frequency and power range. See http://bradsfavorite.com/avoid-interference-5-ghz-wifi-5-8-ghz-cordless-phones/ below the 5GHz Wifi Frequencies for a table with the channel and frequency ranges for routers.
Once everything is clear, you can visit ScanmySpeed.com and have an internet speed test to ensure that there is no disturbance in your connection.
Nov 01, 2014 | Lands Phones
Will a cordless phone interfear with your internet or the cordless phone if its to close to your internet box?
I hope this helps.
I have a wireless network set up in my home. One computer connects, and stays connected, no problem. My laptop however, an Acer, is continually kicked off the internet and I dont know why. I've done all...
Try changing the SSID or network name. You can also try changing channels for your wireless. If you are using a cordless phone, check the frequency of the phone. If it is 2.4 GHZ you will have to change the cordless phone and replace it with a different frequency rating.
Apr 25, 2011 | Computers & Internet
My cable tv, internet service and phone service is thru brighthouse. when house phone rings, the call interrupts my internet service and causes me to loose my internet connection. I took the linksys...
i had the same problem, i ended up removing my one cordless phone that was a 2.4 ghz. and didnt have a problem. my 5.8 ghz cordless phone is still hooked up and doesn't effect it. so i suggest checking you cordless phones
Oct 15, 2010 | Linksys WRT300N Wireless Router
Everytime the phone rings my wireless connection goes away. I am also unable to secure this network. the model number is f5d8235 4
Your phone is using the same frequency as the wireless router (2.4GHz). It would be very difficult to prevent this unless you change:
1. Phone to corded system.
2. Change phone to cordless DECT (5.8GHz) system
3. Change network router from "G" series to "N" series.
Sep 25, 2009 | Computers & Internet
I have a problem I just bought GE 2.4 GHZ phone
I'm not sure if your phone has a channel selection or not, but I know your router does. This issue happens because both wireless internet and cordless phones operate on the same frequency. To change your wireless channel you need to go to your router settings which should be at 192.168.2.1 for a belkin router. To get here you simply type that number where you would normally type a web address in your browser. You enter the username and password and go to wireless settings. Under there you should see something along the lines of channel. The most common channels are 6 and 10, if your router is already on one of these, try another channel. Just keep doing this until you find a channel that your phone is not using and your router should work just fine now.
Jul 20, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
I loose internet when phone is used
You cordless phone is probably using the 2.4Ghz band which is interfering with your wireless network and vice versa. The two can rarely co-exist. I'm afraid you have only 3 choices:
a. Buy a 5.8 Ghz cordless phone
b. Buy a 900Mhz cordless phone
b. Switch to a cord phone
Jun 30, 2009 | Dynex Enhanced-G Wireless Broadband Router
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
Interference from 5.8 GHz cordless phones
I fixed my own problem. I went to the system setup page for the router and changed the channel to another mghz setting. I found one that didn't conflict with the cordless phones. My son is very happy now that he doesn't get kicked out of Halo3 every time we get a phone call.
Mar 27, 2008 | 2wire 2700HG-B Router (2700HGB)
GE cordless phone 2.4 ghz
Your phone must be away from other appliances (i.e. microwaves, radios) and computer equipment (i.e. wireless routers, monitors). The phone runs on 2.4GHz which often conflicts with them.
Mar 15, 2007 | GE 21009GE3 for 21028GE3, 21028GE3,...
Computers & Internet Logo
1,175 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
