Question about Alpine Car Audio & Video
Hooked up new subs in my truck and when I play the radio everything works but when I play a CD or the aux the subs play but not the speakers. Have hooked several decks up and the same thing happens need some help.
  • highflyerkli
    highflyerkli Jan 24, 2013
    I had a car audio dealer hook it up and he swears everything was right. I did take the deck out its an Alpine head unit and the Blue/white wire is hooked to the remote on the amp and I have no clue what wires are what because apparently the guy who hooked it up can't find my manual. Last time I ever go to them.
  • 43 Answers
Go to alpine site and download the installation manual for your model
Posted on Jan 27, 2013
SOURCE: i bought a pioneer deck
did u have your remote wire hooked up right?
Posted on May 13, 2008
unsivilaudio
  • 25 Answers
SOURCE: subwoofer out problem
Thats an installation error. I'm almost 100% sure whoever hooked up your amplifier hooked the amp turn on to your power antenna wire. If there is no amp turn on wire, the accessory wire will do.
Posted on Dec 31, 2008
  • 21 Answers
SOURCE: My amps and subs are working, but my subs aren't hitting.
Try bypassing the remote wire staight to power instead of the stereo
Posted on Oct 27, 2009
  • 17 Answers
SOURCE: kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Posted on Feb 17, 2010
  • 23 Answers
SOURCE: I have an Alpine CDE-100
While I don't know the specifics of this head unit, I would guess that it has settings that can be adjusted for each source. You might check to see if there's a menu that allows you to turn the subs on/off for the various program sources.
Posted on Nov 08, 2010
SUBS NOT WORKING WITH THE CD OR aUX
Since the subs work with the radio, then there is nothing wrong with the speakers themselves. The issue must lie with your radio or control unit.
Jan 20, 2014 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I hooked up a Sony deck and new Kenwood 12' subwoofers and amp that came together in a box set in my 95 Jeep Grand Cherokee and when I play the radio the stock car speakers play but the subwoofers are...
their should be a blue and blue white wire on the Sony radio. cut the blue wire and then connect the car side to the blue white wire and tape off the blue wire that is on the radio side.
the blue wire only turns on when the radio is activated. the blue white wire is activated when the radio is turned on.
please rate my solution.
Jul 02, 2011 | AudioBahn Car Audio & Video
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
YEs i have a Kenwood X592.And my subwoofers only beat when the tuner is on.when i place a cd or my jump drive in all it does is play the music.the subs dont work
you have the remote amplifier turn on wire hooked up wrong. The power antenna goes off when the radio does... so it will lose power when you put in a cd or go to aux.
install the blue wire labled AMP. or REM.
Problem solved.
Dec 24, 2008 | Car Audio & Video
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Sound shuts off, sub still works
That is a common problem with this radio, for it can not go to loud without going down in volume or shutting down.
Dec 08, 2007 | Pioneer DEH-P3100 CD Player
Car Audio & Video Logo
47 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
