Question about HP LaserJet 4 plus Printer
I have a message on my HP Laserjet 4 plus printer and I am getting a message that is blinking "ME FEED COM10" and I can't get it cleared out and I don't have the manual can you help me clear it out please? Thanks you so much Wanda
THis happens to me when an envelope jams. I just put the paper sizer back in regular size and put in a clean piece of paper in the manual feed try. It will reprint the "envelope" on the regular paper and the message goes away. If it doesn't, keep putting paper in until it stops. This has worked for me several times.
Posted on Jan 30, 2009
    Problem Solver:
  • 7 Answers
Replace the network card.
Posted on Jan 28, 2009
When printing from Word Perfect, the message MF Feed Letter comes up and I have to feed pages manually.
This means you send a printjob that needs "Letter" size and tray 2 is set to another size than "Letter". Make sure you set the papersize on the printer the same as the papersize of the printjob. Gerrit Jan
Oct 25, 2009 | HP LaserJet 4 plus Printer
I need cleaning instructions for the HP laser jet 4 plus
First vacuum out all the excess toner you can. Then clean off the feed rollers with a soft cloth dampened with alcohol. As far as the low toner message is concerned, I don't think you can bypass it. You can gently shake the cartridge to redidtribute the toner and temporarily bypass the message, but when the toner level drops again, you'll get the message.
Jun 02, 2009 | HP LaserJet 4 plus Printer
Can't print
It means "manual feed".
Go in to the menu, under paper handling (i think) and turn manual feed "off"
Mar 27, 2009 | HP LaserJet 4 plus Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Hp laserjet 4 plus printer, message window "Ready", off line button shows red
You can try to do a "Cold reset"
turn off the printer hold down  the Menu/reset button and turn it back on.
Do you hear the machine go into rotation? the 4 plus has a high pitch sound follwed by the fuser turning ( you'll know when it does it) if it doesn't go into rotation then there is another problem.
Oct 13, 2007 | HP LaserJet 4 plus Printer
Manual Feed
Press the first button on the left bottom side (shift) and meanwile the third button on the left bottom side (continue). And then it should do the job.
Oct 05, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
