Question about Acer X1320WH WXGA DLP Projector, 2700 Lumens, White EY.JDK04.018
Acer x1320wh fan whistle/whine?
I just bought an acer x1320wh and would like to know from someone who has the exact same model, if they hear a distinct, constant whine/whistle coming from, presumably, one of the fans. it is particularly noticable on startup. I'd like to know this, to determine if it is a defect that can be repaired (replace the fan) or if they are all like that.
  • rich Jan 24, 2013
    BTW - it is very faint, but audible because it is a higher pitch than the noise of the air flow.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 23 Answers
If its new out of the box its under warranty! ! If not you'll have to pay to have the fan unit replaced! You may have just been unlucky and something has entered the slots where the fan exhaust is!! They dont give trouble! In that way, its down to a foreign object! ! Could be even as little as a ball off airoboard packaging. You could get away with just having it cleaned out... (every single part of a laptop is changeable, there built like lego.) Good luck with it!
Posted on Jan 24, 2013
It blinks 10 times
Do you know the specific model? The blinking lights are definitely an indicator of an error, but it could correspond to different things in different models. But to give you an idea it usually means a bad power supply. Depending on the model tv you have it could mean a simple $2 capacitor or a $50 power supply board. Either way...I assume it doesnt turn on....Did you ever hear a faint whine or whistle fromthe tv? If you unplug it....and then plug it in do you hear anything at all?I will try and diagnose it for you if you like....
Feb 28, 2015 | Televison & Video
When turned off the tv makes a whining sound (not the expected whining noise) and then sounds like a wheel (like on Wheel of Fortune) slowly winding down. Yesterday it didn't come on (sound, no picture) so...
The whining if it sounds like a mosquito type whine! it can be a capacitor, i have same issue, you can usually hear when u are on standby but if your hearing like a "wheel of fortune"! and slowing down would likely indicate it's a fan which is possibly covered in dust and the whining is the fan stopped trying to power forward or it slowly moving and slowing down. If you think it's the fan you should unplug your TV to avoid the fan burning out then have someone who knows what their doing take a look at than fan for you and clean the dust away from it, you may be able to get some access through vents in the side and can try your vacuum cleaner in those vents while TV is unplugged but i'd not go messing inside a TV without wearing some rubber gloves!
Looks like the engineer would need to remove TV casing, check fan to see if it is blocked with dust or not, or if just failing for other reason then either clean or replace. If you don't get it done and the fan fails to cool the TV your risking other vital components overheating and breaking for good so best get it looked at, sounds like the fan to me...
Sep 20, 2013 | Samsung HLR5667W 56" Rear Projection HDTV
Rear differential has noise
Rear Diff don't exactly whistle,they whine
Is there fluid in there at the correct level?
Nov 24, 2012 | 1994 Toyota Land Cruiser
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
My laptop just shuts down. I thought it wass because the fan didnt nrun all the time but I bought a vcolloing fan and it still does it. i do not know the exact model but it has about an16 or 17 inch...
I would bet it is still the fan. Even those cooling fans are not enough if that main fan internally isn't working up to par. You need to have that fan replaced or cleaned.
Aug 10, 2010 | Acer Computers & Internet
My Samsung DLP is making a loud humming noise
Most likely if you are hearing a fan like noise from this DLP it is not the fan.
These sets use a replaceable color wheel that before it fails makes either a high pitched whine or a fan like sound.
Part is usually customer replaceable and there are free written instructions and video instructions on YouTube for most models.
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
There is a whistling noise when i let off the accelerator but it stops as soon as i accelerate again. It does happen at idel
Check vacuum hoses in area where you think it's coming from, for being disconnected or cracked.
Mar 27, 2009 | 2000 Jeep Cherokee
High Pitch whine during acceleration
well it could be a few things but most likely you belt is sliping. That is very common and happens to all cars over the years if the belt is not changed. You should check it out. The belt could be bad but it could also be a bad pully. If you dont know what these parts are look them up on google. its very simple
Oct 23, 2008 | 2006 Pontiac Grand Prix
Kdf 55wf655 whistling noise
It could be the fan since many modern fans are speed controlled and fed with chopped voltage with a frequency of a couple of kilohertz which we would interpret as a squeal.
It could also be the impending failure of one of the power circuits which when approaching failure may emit noise in the audible range although they typically operate well above our hearing.
I'm not sure about your set and don't have time to research it right now, but many of the rear projection units have a color wheel that also turns at a high rate and from what I know of them, they are fairly costly to replace.
Those three are possible suspects and of them, only the fan replacement is something the average owner can deal with.
Oct 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Acer X1320WH WXGA DLP Projector, 2700 Lumens, White EY.JDK04.018 Logo
29 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
