Question about GE PFSS2MJySS Bottom Freezer Refrirator Commercial French Door
My ice maker dumps ice in to the lower compartment below the food rack. Can this be adjusted to reduce ice produced?
  • 833 Answers
SOURCE: Gss25wgsd bb model number
Mick...there may be any number of reasons for this. First, check for a bad door gasket. It must be clean and fit snugly around the unit. Use a piece of typing paper about 2 inches wide to pull through. It should pull with some resistance anywhere you try. If it is gappy, humidity can leak in.
Next, make sure the condenser coils are clean. Third, how cold is your freezer? Is should be about 5 degrees or so if it is kept closed for about 6 hours or more.
Is the ice maker clean and not overflowing? Many units can be removed and cleaned out.
You may have other issues...start with these.
Posted on Dec 18, 2007
  • 1122 Answers
SOURCE: Ice maker won't dump
REMOVE THE FRONT PANEL FROM THE ICE MAKER,SEE IF YOU SEE ANY BROKEN GEARS,ALSO THERE IS A HEATER THAT HEATS UP BEFORE THE DUMP CYCLE TO LET THE ICE DROP OUT,THE BEST TO DO IS REPLACE THE ICEMAKER IF TYOU DON'T FIND ANYTHING,YOUR LOCAL APPLIANCE PARTS STORE SHOULD HAVE ONE FOR AROUND $50,EASY TO INSTALL-MIKE
Posted on Mar 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Posted on Aug 16, 2009
  • 5 Answers
SOURCE: Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Posted on Oct 26, 2009
  • 1796 Answers
SOURCE: My GE Profile Artica ice maker is making ice, but
Hi!!
The Ice Maker and the Freezer/Fridge part of the unit work separate, that's why you get the ice made but the freezer can't keep it frozen.
Most likely the condenser, located in the back of the freezer is all frozen and covered with ice pluggin up the air ducts to the fridge, preventing it from cooling.
One quick solution will be unplugging the refrigerator and allowing it to defrost on it’s own or remove the freezer's back panel and using a heat gun or hair dryer to melt the ice, this will take about 20 to 30 min..
There are various reasons this type of problem:
The temp. controls are not set properly. Set controls according to manufacturer recomendation.
The small fan in the freezer is not working,
The defros timer is not working or,
The defrost heater coil is busted.
Once the ice is melted, plug unit back in and check for unit reactions. You should be able to hear the freezer fan working. Also, you'll hear about 4 to 6 times a day the defrost heater melting the ice in the back of the freezer, if NOT, check heater coil for continuity.
Don't forget to rate this post. Good Luck.
Posted on Jun 07, 2010
Water dripping in fridge from below frezer
There is a drain tube that runs from the freezer/ evaporator compartment that allows ice melt water to drain from the defrosting cycle. Often times that drain hole will become clogged with food debris, glass from a broken heating element, paint chips from scaling and mildew, etc. When that drain hole gets clogged the water has no place to go except down into the fresh food compartment. Unplug the ref and remove the food and ice maker and racks. Remove the freezer back panel and look for a drain hole and clean it out. I use a wet/ dry vacuum at first and if the clog is deeper I will use compressed air to blow the line clear. You can also use a water hose with water pressure. Best done outside of the house.
Feb 09, 2014 | Refrigerators
I have a U-Line CLR2060 undercabinet ice maker. The unit will continue dumping batches but the interior temp never gets lower than 49 degrees F....so, ice melts about as quick as it is made. I have...
The storing compartment is not refrigerated so it will melt away the warmer ambient temperature the faster it will melt . also make sure there isn't something producing heat in the compartment
Oct 14, 2013 | U-Line Kitchen Appliances - Others
Amanda side by side wont dump ice. What can I do to fix. Have no money
Hello zinnas - If your refrigerator has completely stop making ice, try checking the following:
· It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
· Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
· When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
· Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
If any of these suggestions prove to be infective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 03, 2013 | Frigidaire FRS6R5EMB Side by Side...
The ice maker is producing very little ice. How
adjust the tempt of the freezer it needs to be around 0 to 5 deg .. . also ck the food around it as it may be blocking the air flow to ice mker .. mm
Jul 01, 2010 | GE PFSS6PKSS
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice maker does not make ice anymore
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
thanks.
Aug 27, 2009 | Whirlpool Refrigerators
Not producing ice
There are several possibilities. The dual water control valve is defective going to the ice maker, defective ice maker thermostat; frozen water fill tube leading to the ice maker is blocked with ice. You can see if ice maker is working by filling it with tap water and waiting to see if it dumps. If it does not empty the icemaker of the ice I would think ice maker thermostat. If it dumps ice and does not refill I would say you need a new dual water control valve. Sears has a complete model number system that is confusing I know. Sears made it that way. Not sure why but look around the cold food door while open and look near bottom on the frame just above the kick plate. The number looks like this, (model No. 253.64802400 for example) I will need that number to help you solve the sound alert coming from your refrigerator. Find that number and we can go from there, Thanks, Sea Breeze
Jun 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
GE PFSS2MJySS Bottom Freezer Refrirator Commercial French Door Logo
15 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
