Question about Euro-Pro Sewing Machines
I have no Hand Book for Model # 100-547H-Serger machine
It is a Sergert 4 spool 120v-60Hz-100w Conforms to(8th edition) 1993. Cert. to Can/CSA. C22.2 #. 68-92 (R1999)---- I so hope you can help me
  • Euro-Pro Master
  • 7,365 Answers
Try calling or email these sites about a manual
sewvacdoctor.com
a1sewingmachines.com
Posted on Jan 24, 2013
5 Suggested Answers
SOURCE: brother serger
go to brother.com and download the manual for free!
Posted on Jan 14, 2009
  • 10865 Answers
SOURCE: Need manual for singer serger model # 14sh654
Hi Wendy. Go to this web address and you can order what you need. http://www.sewingmachineparts.net/index.html
Please remember to rate my answer. thanks.
Posted on Feb 05, 2009
trial2962
  • 107 Answers
SOURCE: need a manual for a baby lock serger model EA-605
You might take a look on ebay item 160362974035
Posted on Jan 14, 2010
hazelgrace
  • 340 Answers
SOURCE: bought this brother sewing machine
Do you need a manual for it?
Manuals are available from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
I can't help you with finding out the model, but finding the right manual should help you do that.
Unfortunately it will mean trawling through all the manuals until you find the right one!
Hope this helps!
Posted on Oct 29, 2010
Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
You have a nice serger, so let's start with some basics:
Is your serger cleaned?
Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
May 05, 2014 | Brother 925D Serger
Have an Toyota 6600 model Serger. The knives won't cut, won't stitch and tread keeps breaking from the right hand needle...
you might want to replace the knives
you might have the serger checked for a timing problem
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
10. If all of the above suggestions don't help then the serger needs to be checked for a timing problem at a sewing machine repair shop.
Nov 05, 2013 | Sewing Machines
How do you thread a three spool serger
This machine is not a serger, it is a sewing machine go to to www.singerco.com customer support and check your model number.
Aug 22, 2010 | Singer 3116 Simple
Left needle thread keeps breaking on my White Superlock 2000 ATS serger
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
May 02, 2010 | White Sewing Superlock 2000 ATS Mechanical...
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
Feb 05, 2009 | Sewing Machines
Need a manual for a baby lock serger model EA-605
Jan 16, 2009 | Baby Lock Eclipse Serger
How to thread my machine
I did not have a Serger, all I have is an old sewing maching but appeared to thread from the left slot and any machine that I have had always threaded from the right side. Anyway, I found a neighbor who was able to figure it out. I would love to get a directional book for the machine if that was possible. The machine is a Brother Model No. VX581.
Nov 15, 2008 | Brother Lay-In Thread Serger Mechanical...
Sewing Machines Logo
93 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
