Here is some tips to avoid paper jam..
**If you need any kind of technical assistance you can contact support cell at here
SOURCE: my printer always tells me paper jam
the issue can be found when the paper feed rolls in the printer or the internal encoder strip are dirty.
Please try the following:
- open the backdoor of the printer
- also open the front door
- unplug the power chord without shutting down the printer
- now clean the paper feed rolls inside the printer with a soft rubber
- turn the rolls some times (10 tries or so) from down to up
- close the backdoor
- move the cartridge cart some times from one side to the other
- now you see a transparent strip over the metal bar
- this strip you can clean with cleaning alcohol
(be carefully! don't loose the strip or take too much alcohol)
- now let the printer dry over night (let it be open)
- next morning, close the front door
- press # and 6 at the same time and hold them
- keep them pressed and plug in the power chord
- keep them pressed until you see "semi nvm reset"
done
Hope it helps,
Henning
SOURCE: Printer will start the printing
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English). If
you need more help come back. Post
/ thumbs / testimonial are welcome!
