TRYING TO INSTALL IN A DELL DIMIENSION L800R
REFUSES TO BOOT. HANGS UP. PIN SETTINGS?
  • four_ehver Jan 28, 2009
    I'm trying to replace the hard dive(SeaGate U Series 5) with a Western Digital WD400. On boot, all I get is a blinking cursor. HELP!!
  • djsam112 May 11, 2010
    I am not sure what exactly you are asking. Please state exactly what is said on the monitor when you try and boot up the computer. Is this a new computer if not were you trying to install something or change something on the insides?
    Once i have this information I should be able to further assist you.
    Thank you
  • 32 Answers
Are you replacing or adding?
If you are adding a hard drive as slave read the following if not skip down to "Replacing"
-Make sure your hdd jumpers are set to either slave or cs (Cable Select)
-Go into your BIOS (normally f2 when you turn on power) and make sure the old Hard Drive (The one with windows installed) is on the top or first to boot in the boot priority menu.
Now restart and see if it works
REPLACING
1. Find your Operating System install CD (Windows)
2. make sure power is off and plug in back is pulled when you are working on the inside of and computer
3. Replace Hard Drive making sure the jumper is set to either Master or CS (Cable Select)
4. Plug computer in and turn on power
5. Insert Windows/OS CD
6. If it doesnt detect the CD try restarting, if it still doesnt detect it go into the BIOS (normally f2 when you turn on power) and make sure the boot priority allows CD to go first.
7. Install windows
8. Install Drivers (if the installation disk didnt already)
This should solve your problem
Have a great Day.
Posted on Jan 28, 2009
  • 50 Answers
First let the motherboard detect your hardisk, if the motherboard detects your hardisk, that means that your hardisk is just ok, then pull out the memory of your mobo and clean it out with a pencil eraser, then turn on your computer, if the problem still the same, pull out the processor also and clean it with a pencil eraser also, and insert back the processor to its proper place, then turn on your computer, if the problem is still the same, just repair or reformat your hardisk by using a windows installer, and make a backup of your files that are important. hope this help
Good luck
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
My notebook stops 75% through the bootloader (standard boot loader, came with the system) and refuses to accept any commands. Help, please?
If you press F2 during the Boot process it will take you to Cmos and you can find "Load Defaults" under the last tab at the top. Chose Defaults and Save and Exit. This should allow the boot to proceed normal. Something got messed up in Cmos settings. The sure fire way to resolve is to accept the Default Settings. Good Luck. pmgibs1@verizon.net if you can not resolve Phil
May 24, 2010 | Dell Inspiron 1526 Notebook
My dell xps m1330 will not boot up.it comes up on screen saying ''no boot sector on internal hard drive'' ''no bootable devices''it has had a new motherboard fitted by Dell.i'm trying to install xp pro
When it's booting, try to access the setup, aka BIOS. See if you can set CD/DVD as a booting option. As the top BOOT device. Then see if you can boot your installation CD. You may be able to format your drive during the installation - if the hard drive hasn't failed?
Nov 23, 2009 | Dell XPS M1330 Notebook
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
How do I get into safe mode on a Dell Inspiron 531. PF 8 doesn't do it?I can only get into Setup with PF2. Otherwise the boot up only goes to the DELL screen and hangs there.
You cant get in safe mode because the PC hangs before windows ever try to start.
Try to press F8 multiple times but right after the Dell screen.
Some computer don't like that you press F8 while the bios is loading and just hangs there, maybe its your case.
Oct 27, 2009 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Computer hangs during boot up after instlaling lexmark 6650 print
This is a problem I've seen with Dell PCs, what it is doing is trying to boot from the card reader on the printer. My PC had this problem, and a Dell BIOS upgrade fixed it. It would even try to boot from USB keys or mp3 players I left in the USB slot! So I have a feeling you have the same problem I had.
If you don't feel comfortable updating the BIOS, then contact Dell and maybe they can walk you through it.
Mar 30, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
The Motherboard refuses to allow for Hard disk formatting
Hi , Because the 1st boot option should be Hard Disk in the BIOS save and exit and then boot
Mar 22, 2009 | Computers & Internet
Dell d600 video problem
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Computers & Internet Logo
262 people viewed this question
David Payne
David Payne
