Jusst as half crazy stated, keys are locked together. When I type 5 I see 'bt5'. 'y' ...'ny6'. How can I fix this?
How do I get the car started after changing the instrument cluster on a 2001 jaguar s type how do i get my 2001 jaguar s type started, i change my instrument cluster
disconnect battery and join the leads together ,leave for half hour and try to start ,if it still will not start call the garage ,,,did you damage the transponder key reader around the ignition lock or forget to reconnect it ??
Jan 05, 2016 | Jaguar Cars & Trucks
How do i fix my keyboard so that half of the keys dont type numbers
Hi
You probably have a multifunctional keyboard - so there is a key somewhere that is currently in its "on" state. It is usually located along the top or bottom of your keyboard and marked function / num.lock (numerical lock) or something similar.
Hope this helps
Feb 18, 2015 | Computers & Internet
Door locks go crazy locking and unlocking
A Central locking solenoid, stuck half way through cycle, its a matter of finding out which one? Had a Ford that did that when the weather was below freezing. It is likely to be a rear lock, because you can over ride the front doors with the key. Hope that helps
Jan 28, 2014 | 2000 Mercury Sable
How to know the Cap Lock is on or off for my Microsoft wireless keyboard 4000?
I don't have one of these keyboards, but there is usually a small led built into the caps lock key to indicate the lock is on, Push the caps lock key, and observe if any leds are changing state. If they are, it's the indicator led.
Otherwise, you will have to open Wordpad and type...to see the state of the key. It's possible the led isn't working, so check it's state in Wordpad.
Good luck, and hope this helps.
Feb 13, 2011 | Microsoft Wireless Laser Desktop 4000...
I have a pathfinder se diesel 2008,last week the key lock door sistem became crazy,some times the door lock doesnt work and suddenly work normal.
Hello NISSON EXPERT HERE, Please take this information seriously from a certified auto shop owner. In order to reset the key lock door system to prevent it from continuing to become crazy, Please remove the red lead from your vehicle battery and replace the lead. This will reset the security system so that the error goes away permanently! QUICK FIX FOR A TEDIOUS PROBLEM!!
Jan 21, 2011 | 2008 Nissan Pathfinder
Half of key broke off inside trunk lock
you need to have the trunk open and the lock unlocked first then you can get the barrel out of the lock and remove the broken part of the key,,,so dont lock the trunk till you get it fixed,,,
Jun 20, 2010 | 1998 Toyota Camry
Just had my kwikset dead bolt lock rekeyed. i put it back on the door and now you can't pull the key out after you lock the door. please help
Sounds like its binding. Loosen the screws that hold the 2 halfs together. Get the key to work smothly. snug the screws and try again. If ok then tighten the rest of the way.
Sep 24, 2009 | Kwikset Locks & Locksmithing
When I pres j on the screen comes 1.how to fix
Num lock is turned on on your keyboard.
I presume when you press I it comes up with 5?
Just press num lock key and your problem will be solved.
Jun 18, 2009 | Dell Inspiron 1501 Notebook
Only half my letter's work!
you are correct, the number lock is on, use the blue "FN" key and in blue under the "ins" key you should see "Num LK" push the two together and presto, normal keyboard
Feb 28, 2008 | Compaq Armada E500 Notebook
Computers & Internet Logo
David Payne
David Payne
