Question about Plumbing
Moen shower faucet la forma tub/shower model#2448
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
SOURCE: just installed shower and faucet in bath tub when
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Posted on Mar 16, 2009
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Posted on Apr 06, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 129 Answers
SOURCE: the shower control valve for my moen 2995 faucet
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Posted on Sep 28, 2009
Installed a new moen adler tub faucet with shower diverter. When you turn on the shower water continues to come out of the tub faucet. Is there an adjustment or is it just the way it is??
Our Moen always dribbled a little since the diverter is metal-to-metal and doesn't really have any seal. The loss shouldn't be a stream though.
Nov 11, 2010 | Moen & One Handle Tub & Shower Faucet
We have a new shower. Water comes out of shower head and tub faucet together. What do I need to do?
its because that model usually when u pull for the shower is not properly connected. You will have to remove handle and coverplate, then shine flashlight down to see what is happening when pulling rod on tub spout for shower. Usually its broken or bent and just needs new one installed. It cost me 2 buck for new shower rod. Directions u can get free from Moen with free lifetime parts.
Oct 06, 2010 | Moen & One Handle Tub & Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
Plumbing Logo
23 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
