Water not filling in washer and water pipe is connected
  • Washing Mach... Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 24, 2013
jtate9
  • 68 Answers
SOURCE: GE WJSR 1070A Leaking
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
MNTECH
  • 1543 Answers
SOURCE: Water Surge Making Pipes Knock
What you are describing is called "water hammering" and is caused when a water valve shuts off quickly. The momentum of the water moving within the pipe causes the pipe to bang when it comes to a sudden stop. Plumbers can install an air chamber to absorb the water hammer (just like a shock absorber) but you might try ones that you can just screw onto the hoses behind the washer. I have seen them at places like Home Depot in the plumbing department. (hope you can find someone who actually knows what you are talking about to help you find them) Alternately, you may be able to find them at a hardware store or appliance parts supplier.
Posted on Feb 01, 2009
  • 423 Answers
SOURCE: will not fill with water
It is hard to provide great guidance to you without knowing the manufacturer and model number, but I have found that some lower end washing machines will not fill or operate without the door being closed. (I know this sounds too simplistic, but this actually happened to me.)
If this does not solve your problem, please post back here and we can take the next step. OK?
Posted on Apr 20, 2009
  • 7 Answers
SOURCE: when washer filling, water supply pipes begin to vibrate
Your Tap is turned on to far. If you turn it down slowly the noise will stop.
Posted on May 13, 2009
  • 154 Answers
SOURCE: whirlpool top load washer makes noise on filling
Its mainly caused by back pressure when the inlet valve suddenly shuts off the water to the machine. The pressure causes your plumbing pipe work to shake inside the walls.
You can turn down the pressure by closing your water tap and only having it slightly open. Or you can get pressure limiters which join on the hose.
Regards
Ash
Posted on Oct 27, 2009
Can only run washer on small load,anything bigger,water just runs out drain.Small loads are killing us,its an extra load,top washer
Check the position of your drain hose in the pipe or sink. It's probably too low relative to the washer tub fill level. You need to make sure that the end of the hose is higher than the maximum fill level of the washer tub. (The pump in the washer can push the water up to 3-5' higher than the washer. So if you have the hose connecting to a drain pipe, it should be at least 3 1/2-4' high if the washer is on the floor. If you have your drain hose directed to flow into a sink, you may need to raise the sink or put a pipe into the sink to raise the drain hose. If you add a drain pipe, you'll need to make sure it won't shift when the washer pumps out the water.)
I hope this helps.
Feb 10, 2015 | Washing Machines
Drum fill with water
If your machine outlet pipe is connected to the sink trap (many are these days) it could simply be that water from the sink is draining into the washer if it is connected like this ensure that where the outlet pipe leaves the the trap it goes up and does not run level or down if the water in the is dirty this is the problem failing this water vavles are passing water when the machine is off
Mar 03, 2014 | Whirlpool 3.5 Cu. Ft. White Front Load...
Water is draining continously from tank
its over filling its the soilnoid valve letting by u will need to replace it
Aug 26, 2012 | Electrolux Washing Machines
DOES MY WIXL143S INDESIT USE HOT OR COLD MAINS
That's easy to tell- if it has 2 inlet pipe/hose connections at the back (as opposed to the outlet pipe which is permanently connected to the washer and hooks over the outlet drain) then it is a hot and cold fill. If there is only one inlet pipe it is cold fill only. Either type HAS to have a cold fill supply- to lower the temperature of the hot water for cool washes AND for rinsing which is normally cold water only.
If you have only a cold water tap/fawcet available for the washer and it is a hot and cold fill you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Hope this has clarified!
John C
Oct 29, 2011 | Indesit W 123 Front Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Hello. My washing mashine awt 2285 is washing only with cold wather. How can I repair the termostat. Thank you for your help
If your washer is hot and cold fill (2 inlet water pipes connected), it is possible that the hot water inlet valve is malfunctioning. You can test this by feeling if the hot water inlet pipe gets hot when the washer is supposed to be filling with hot water.
If you washer is cold fill only it is possible that either the programming is malfunctioning or, more likely in my opinion, the heating element is malfunctioning/broken and requires replacement.
Good luck,
John C
Mar 03, 2011 | Washing Machines
Washer fills with hot water even when unplugged
The freezing messed up the fill valve. This is the part that your hoses connect to on the back of the washer. Replace it and you will be fine.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
