Question about Utilitech 1-HP 18-GPM 3-Wire 230-Volt Submersible Well Pump UT3183
Utilitech 1-HP 18-GPM 3-Wire 230-Volt Submersible Well Pump bought 12/23 new wire - installed by licensed electrican 3 wire bundle-was operating fine-taking a shower, water just stopped- electrician back out today-power is fine- pressure tank is full-when the lid is removed from the well and fuses plugged back in you see the lid give a little turn, which electrician says is pump trying to come on, dropped a line, water at 30ft, the pump is down 160 plus ft, now we have to pull that thing out again, which is a piece of work-electrician says it has to come out-problem is not up top
  • 512 Answers
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Posted on Sep 16, 2012
hunter19_46m
  • 7482 Answers
SOURCE: I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground li
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Posted on Oct 25, 2012
boysor2933
  • 293 Answers
SOURCE: I have a utilitech jet pump in which i have to turn off the power switch and wait ten minute, then turn it back on so it could run the water.
An electrical fault is tripping off the power relay. Check the current draw of the pump motor.
Posted on Nov 06, 2012
boysor2933
  • 293 Answers
SOURCE: I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
boysor2933
  • 293 Answers
SOURCE: I bought a unitech 1/2 hp transfer utility pump. I would like to remove coming uderground water fron the shallow pit. What happened after the pump remove this water. When the new water come isit start
Install a foot valve (check valve) at the end of the suction line so that you don't have to prime it again. Install a level controller so that it will automatically switch on and off according to your predetermined high and low water levels.
Where can I buy an adaptor for a Utilitech 1/3 HP Submersible Pump #0435062, PPSU33? I called Utilitech and they were no help.
the best place to get help here is from a pump and irrigation supply shop
they will have everything needed to operate the pump
Feb 08, 2017 | HP Plumbing
Looking for a new motor for a utilitech pro 0313836 submersible pump
Most submersible pump motors are interchangeable.
A 230 V motor will run cheaper. Be sure to get the correct HP motor.
Oct 05, 2014 | Utilitech 1-1/2-HP 18-GPM 3-Wire 230-Volt...
Is there a switch that cuts pump off if well is out of water on pump?
They're made and called a low pressure shut off switch. I know square D makes them or at least they did 40 years ago.
Sep 28, 2014 | Utilitech 3/4-HP 10-GPM 2-Wire 230-Volt...
Purchased new well pump have electric however the pump will not start
Does the pump hum? Sounds like start capacitor is bad in control box.
Apr 03, 2014 | Utilitech 1-HP 18-GPM 3-Wire 230-Volt...
Need warranty papers
This is fixya we would not have a copy of your warranty with Amex .
Nov 04, 2017 | Utilitech 1/2-HP 10-GPM 2-Wire 230-Volt...
Short in well
the best would be to rewire and check if its running in a bucket of water, if all is ok then seal it with a epoxy resin cast
Apr 07, 2013 | Utilitech 1/2-HP 10-GPM 2-Wire 230-Volt...
I have a 3/4 hp Flotec 4022 pump. Prior to that I had a goulds 1 hp pump on the same 120 circuit with no issues. The Goulds pump housing started to go so I replaced it. Since replacing it with the Flotec I...
Hi Eglenni,
Here are the specs for your pump:
Thermoplastic Shallow Well Jet Pump 3/4 HP. This new revision of an "old hand" provides good pressure pumping from wells where the depth-to-water is 25' or less.
BODY CONSTRUCTION: Thermoplastic
HORSEPOWER: 3/4
MAXIMUM CAPACITY: 12 GPM
FLOW at 10' LIFT and 40 PSI: 9.7 GPM
MAX LIFT: 25'
MAXIMUM PRESSURE: 78 psi
PRESSURE SWITCH SETTING: 30/50
SUCTION PIPE SIZE: 1-1/4" NPT
DISCHARGE PIPE SIZE: 1" NPT
AMP DRAW (full load): 6.1 amps on 230v / 12.2 amps on 115v
VOLTAGE: 230v / 115v, 60 Hz
RECOMMENDED BREAKER: 15 amp on 230v / 20 amp on 115v
MAXIMUM WATER TEMPERATURE: 140 °F (60 °C)
Note that this pump can be operated at 115 volts or 230 volts (A/C) It may have come wired for 230 volt use from the vendor.
Make sure the pump is piped correctly.
There should be a wiring diagram either on the pump or in the literature so you can check to see how the pump is wired.
MAKE SURE
you have the pump wired for 115 volt use in your case. Also make sure the wire size is #12 awg for the power wiring.
Make sure all connections are tight. If you have an amprobe (an instrument that measures electric current) you can check to see how many amps the pump is pulling when it runs.
You said your old pump was 1 HP. This Flotec pump is 3/4 horse so there could be some pump performance loss depending on the well depth and length of the piping runs.
Here's the link to the website for the pump. There are additional resources available on the website:
Thermoplastic Shallow Well Jet Pump 3 4 HP
Jul 05, 2017 | Northern Tool Electrical Supplies
How do you wire a 2 wire Franklin 1/2 HP 10 GPM
you can just install a regular plug to the end of the wires and plug it in,, but you will need to add a ground wire,, if there is only 2 wires there should be 3 so look for a screw with a spiral clasp on it for the ground,,
Apr 21, 2009 | Franklin ELECTRIC/LITTLE GIANT PUMP 1/4HP...
Utilitech 1-HP 18-GPM 3-Wire 230-Volt Submersible Well Pump UT3183 Logo
99 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
Dave
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
