Question about Panasonic RX-D26EB-S Boombox
Loose play/pause button on panasonic RX-D26
I would like to remove the shell in order to access the play/pause button, which is loose and toggles, for either replacement or repair.
Start/pause button is not working on my LG washing machine. All other buttons are working fine?
Problem maybe that the START/PAUSE button has broken loose from the control panel. All the buttons are attached to control panel and "hinged" so when you press the button, the button presses a small button switch on the display control. You may have to order
the Control Panel.. Disassembly is required to inspect.
It would be least likely that the Display PCB is bad..
Aug 19, 2014 | LG WM1814CW Front Load Washer
Nv ds55b pause record button loose
The little silicone diaphragm spring, which carries a small graphite connector, will have split. There is no glue which will stick to the silicone, so you have to replace it with a new one.
May 23, 2012 | Panasonic NV-DS55B Mini DV Digital...
Hi, I recently purchased a Panasonic DVD S48 dvd player. I was assuming when I bought it that it was a multiregion product. This seems not to be the case as it will not play region 1 dvd's that I...
hi Pjkgbr.
this is all i could find out, now if you do try this do so at your own risk.
This hack requires the S48 remote plus a universal remote configured for the S48 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
I used a cheap universal remote.
1. Select DVD device on remote.
2. Hold magic button until the DVD button blinks twice.
3. Enter device code 0490 (DVD button blinks twice)
Neither the 'Play/Pause' nor 'Frame' buttons on the S48 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S48 remote press Audio, 1, 9, 8, 2, Subtitle
4. Using the other remote (URC 7562) press Pause.
5. Using the S48 remote press 0.
The DVD front panel should now show the text "on".
The DVD should now be region-free. Region code hack posted by spook65, December 12 2012:
DVD-S48EG-K (Region 2)
This is the process for unlocking, the Panasonic DVD-S48 for
multi-zone.
Please note, you will need a universal remote control which
has a PAUSE button in order to unlock this player.
1. Turn the power ON
2. Open the disc tray
3. Using the remotes, press AUDIO 1 9 8 2 SUBTITLE PAUSE 0
4. Switch the player to STANDBY and then switch ON again.
The display should read ON after you enter PAUSE 0.
If this doesn't happen, switch the player off and start the
sequence again.
The remote supplied with Panasonic player has a PLAY/PAUSE
button rather than a separate PAUSE button. If you use the
PLAY/PAUSE button, the tray will close and the unlock
sequence will be aborted.
To get round this, you need a universal remote set-up to use
with the DVD player. After pressing SUBTITLE on the
Panasonic remote, quickly press the PAUSE button on the
universal remote, then press 0 on the Panasonic remote to
complete to unlock code entry.
or this one.
What is the process for Multizoning a DVD-S38 / DVD-S48 / DVD-S58 / DVD-S68 / DVD-S500 / DVD-S700 DVD Player? Providing your DVD Player is one of the below models, you can multizone the unit yourself using the remote supplied with the product and another Panasonic product remote thas a Pause button on it
Applicable Models:
Multizoning Process:
1. Power on the unit and open the disc tray
2. Using the remote that came with the player, press the following buttons in sequence
3. AUDIO 1 9 8 2
4. SUBTITLE
5. Using the other Panasonic Remote (not the one that came with the player), press the PAUSE button
6. On the remote that came with the DVD player, press the 0 (zero) button
7. If you have followed the above process correctly, the word ON should be shown on the front panel display of the player*1
*1 Please note: The models DVD-S500 and DVD-S700 do not have a front panel display,
so the only way of confirming that the multizoning process has been done correctly, is to
try playing a DVD disc from another region code other than region 4
Dec 05, 2017 | Televison & Video
I have a cda-9883 alpine that is in demo how can i take it off demo and have it play normal?
hold down the function button until the display changes. you can then toggle things like dimmer ,aux, and demo by turning volume control. when you see demo push the play/pause button which will then allow you to turn it off by again turning the volume button. once its off press play/pause button which will allow you to toggle other functions. then hold function key down again to get back to main display(main display will eventually return on its own)
Dec 10, 2010 | Car Audio & Video
How do i unlock the panasonic dvd-s38 to play all region dvds
In addtion to the S68/S38 remote this hack requires a universal remote configured for the S58/S38 with a separate 'Pause' button (or another Panasonic DVD remote with a separate 'Pause' button may work).
Neither the 'Play/Pause' nor 'Frame' buttons on the S58/S38 remote work for this hack.
1. Power on.
2. Open tray.
3. Using the S58/S38 remote press Audio, 1, 9, 8, 2, Subtitle
(it is not required but, if the TV is on, it will display the 'no go' icon after each key press - ignore it).
4. Using the other remote press Pause.
5. Using the S38 remote press 0.
If so, the DVD is region-free.
Dec 06, 2010 | Panasonic Dvds38 Dvd Player
How Do I change the alternator belt on a Lexus 1999 RX 300?
loose bolt A (but don't remove)
and turn bolt B anticlockwise till ur belt loose
if its not loosing the belt bolt B will come out then pull the belt up and down
then remove and fix the belt
May 08, 2010 | 1999 Lexus RX 300
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Want to make a combined play pause button
I am figuring our what it looks like when you have suspended switches for two operations in a single switch. We don't find any double toggle switch in the market aside from electrical devices. You cannot combine switch wires from the motherboard to the button. It is good to explore for that yet you have 80% risk. But if we can place double throw switch just like what is done in digital radio/amplifier systems, the problem is where to fit in a case.
May 07, 2009 | Computers & Internet
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Panasonic RX-D26EB-S Boombox Logo
42 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
