Question about RCA P52926 52" Rear Projection Television
Fly backtransformer for itc222a chassis - RCA P52926 52" Rear Projection Television
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
I cannot find the convergence functions on my tv
Sounds like your talking about an RCA HDTV with the ITC222 or ITC222A chassis. If so the ITC222a Convergence option missing repair kit at the following link will repair that issue. www.tvrepairworld.com
Aug 21, 2009 | Televison & Video
Television will not powwer on
Hello al1895,
This model of TV uses the ITC222A chassis. This is a common problem in this unit. The problem is usually centered around 4 capacitors (CP140, CP150, CP110, and CP114) They usually vent (becom bloated or puffy) and develop an internal short which causes the TV to shut down. This is usually caused by power surges (even when connected to a surge protector). The repair for this problem does not cost much, and I would suggest that you have a TV repair technician examine this TV due to the other problems that can happen with this chassis (ITC222A).
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jul 27, 2009 | RCA HD52W59 HDTV Projection Television
Do similar problems happen with the R52WM24 model?
thats the itc222a chassis, they have a bad service record
Jul 11, 2009 | RCA HD52W56 52" Rear Projection HDTV
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA P52926 52" Rear Projection Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
