Question about Citizen CLP-621 Label Printer
LABEL NOT PRINTING CLEARLY
The right side of the label is not printing clearly. Its very faded, but the rest of the label is printing perfectly, and I changed the ribbon as well. Please help
  • 44 Answers
On the right hand side of the print head is a blue thumb wheel. ensure this is set position 9, this will give you full width print. This adjustment is for setting narrow width labels.
Posted on Sep 04, 2014
2 Suggested Answers
dddriver
  • 107 Answers
SOURCE: I am a Reseller and one of my client is having
I have used this type of printer before. Long ago when it was called the C-ITOH. However, never had to change the print head before. I would imagine that if you did - all the adjustments would need changing. Bad Gap would skip labels and bad pressure would make them too light or too dark. If there are any vertical lines (even faint) the print head is damaged. Also, these things are very specific as to media vs ink roller. You cannot use a paper ink roller with mylar labels. Vise versa works but those rolls are more expensive. I am sure you have tested this already but you point pretty exclusively to the "new" print head with your testing. Sounds like you have answered your own question. I would do some continuity tests on the head to see if it carries any current at all. Good Luck!
Posted on Jun 14, 2011
The printing is fading, more so on left of label, but also on right side of label
Try cleaning the thermal print head. If that doesn't do the trick, the printhead may be defective.
Jan 07, 2011 | Zebra 105SL Thermal Label Printer
One label printing over two label forms
Always check to make sure the printer is advancing one label at a time by itself before printing. If it does then you know the printer has a good read on the label size. Then if it misaligns when printing then you know the problem is in the printer driver because the printer is only going to do what it's told to do.
So best is to turn printer off, power up, press feed to see if one label feeds ok. If the label feed is off at this point then the printer needs to be calibrated which is done by pressing and holding FEED while turning the printer on.
Hope that helps !
Jun 03, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My zebra only prints the left half? I have tried calibrating, it does nothing. Can you help me out? Thanks
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Best way to check this is to take your tallest and widest label and print out a configuration label. This is done by turning off the priner, pressing the CANCEL key and holding while turning on the printer. Release the button when the calibrate led turns off. A config label will print and you can check the setting for PRINT WIDTH.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles the press down on the printhead and the pressure can be adjusted on each by turning the knob on top. Readjust the right side until printing returns across the label.
Hope that helps !
Apr 26, 2010 | Zebra Stripe S600 Thermal Label Printer
I want to adjust the printing coz its prinnting on left side my barcode label size is from the right side is having more space
Not too sure what you mean here. If the print on the left side is Ok and faded on the right side, then the position of the printhead pressure toggle may need to be adjusted. Make sure it is positioned over the center of your label.
Hope that helps !
Apr 21, 2010 | Zebra 105Se Thermal Printer
PRINTS ON ONLY HALF OF THE LABEL
If the printing clearly stops, then the maximum width setting of the printer is not set to the full 4 inches (104mm) of the printhead. Go into the setup mode on the printer and look for the setting called PRINT WIDTH and make sure it's set to 104mm or close to that. If printing is only half way across the label, it's because the width is set to something less than 104mm.
if the print fades away off the label, that is due to an imbalance in the pressure across the printhead.
Hope that helps !
Feb 18, 2010 | Zebra Z4Mplus Label Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
After changing the print head and setting the Ohm resistance, the left side of the printed labels are faded. I adjusted both head pressure and slid them back and forth but I can't get it to print right....
It's very possible the printhead wasn't installed correctly. It's pretty easy to get it wrong, as there are two pins on the latched printhead bracket that have to fit into two holes on the printhead itself. You have to get the alignment of these pins and holes just perfect before you tighten the screw. You have to make sure the aluminum plate on the printhead is sitting flat against the printer's printhead bracket before you turn the screw on top of the bracket.
Sep 24, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Faint type on metallic refills
Faded print is nearly always the 1st sign the batteries are nearly worn out - try new batteries. (it could be that metalic tape requires more power to print than the paper tape)
Jan 18, 2009 | Dymo LetraTAG Thermal Label Printer
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
Printing fade at the midle of the page
Build up on the printhead, printhead pressure, or worn platen roller...
Apr 26, 2007 | Zebra Stripe S600 Thermal Label Printer
Citizen CLP-621 Label Printer Logo
118 people viewed this question
Top Citizen Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
