Smartdisk Firelite model usbflb80 is not recognized on my laptop
It was working fine, the just stopped. When I plug it up, it makes a clicking sound, and then the light starts to flash.
  • 27,725 Answers
A USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Or even get a usb 3 lead. USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Sometimes they become faulty due to overstretching age or heavy objects sitting on top of them. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. Windows 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error. This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition. Now I have seen cases where Malware can break the link of a Hard Drive. So let's try a couple of steps. Let's go back in to "Disk Management" Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths" Now try selecting a new Drive Letter. This will restore the path if it has been broken. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Posted on Jan 24, 2013
jackboy
  • 2985 Answers
SOURCE: smartdisk firelite won't be recognized on desktop-will on laptop
You have not said what system your computers are wroking under I would think your Sony is XP/2000 But the Dell is Win 98 - An I right? IF this is the case it means the drive has been formatted to NTFS which be read only on XO/2000 machines. The thing to do here is to load all your filed onto the Sony Then refomat to 32 bit - this makes a universal device but your Dell if I am right will not see the lappies stuff Come back with more detail
Posted on Jul 31, 2007
SOURCE: Smartdisk Firelite usbflb80 stopped working
My Smartdisk Firelite 80 gig Mini-Drive will not power up when plugged into the front or rear USB Ports (Windows XP Pro System). Last used successfully on 4-Apr-08 with no issues. Any suggestions?
Posted on Apr 07, 2008
SOURCE: Smartdisk Firelite 80GB-Stopped Working
I had the same problem with my firelite usbflb80-c, and carefully took the case off, 4 screws (one screw under the void if broken warranty sticker) my drive had somehow wiggled it's way out if the connection pins. Figures, with 5 yrs of use, all the traveling and occasional dropping. So I carefully pushed the drive back in place until I couldn't see connection pins any more. I plugged it into my computer before I closed it back up. THANKFULLY an easy fix, but I double checked for breaks or cracks before I closed it up. :o) YAY, I thought I had lost all my files!
Posted on Apr 23, 2009
  • 22 Answers
SOURCE: New computer won't recognize my Firelite, works on old computer
You need drivers for USB, if you remember when you bought smartdisk you got the installation disc, that you now need for a new computer.
Posted on Oct 31, 2009
lock123
  • 6831 Answers
SOURCE: (Smartdisk)firelite 40G external hard drive wont work with vista
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
I have an old laptop with files that cannot connect to internet. It runs Windows 98SE so I need a special driver file for my SmartDisk Firelite USBFLB80-C unit. How can I get the file so I can burn it to...
may you can plug off your hard drive, and tthen connect to the computer that can connect to internet, and then just copy your file to your another one hard drive or you can bur it to cd
Dec 02, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
How do I open a smartdisk firelite model # USBFLB40
Go ti My computer icon, right click on it and click on explore. Should be show your new drive. If this is the case, right click the new HD in click on explore to see what is in there. My PC Doctor NJ
Mar 26, 2010 | FireLite (USBFLB80) Hard Drive
I have a firelite smartdisk portable hard drive usbflb40. I need th driver for it. Where can I down load it. Thanks
http://drivers.softpedia.com/get/Other-DRIVERS-TOOLS/Others/SmartDisk-FireLite-Driver.shtml
there you go!
Feb 25, 2010 | FireLite (USBFLB80) Hard Drive
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
Feb 22, 2008 | FireLite (USBFLB80) Hard Drive
Firelite 30gig
Click on the link, or copy past the link, open the page scroll down and you will find Free Driver Download SmartDisk FireLite USB Driver Windows 98SE
this will work for win98 as well as 98SE (second edition) too.
http://www.opendrivers.com/driver/226844/smartdisk-firelite-usb-driver-windows-98se-free-download.html
Please let me know if it worked will be appreciated.
Regards
Moses
Jan 17, 2008 | FireLite (USBFLB80) Hard Drive
Jan 15, 2008 | FireLite (USBFLB80) Hard Drive
Firelite 160gb HD not recognized
Make sure that there is no "HD protection", in which the hard drive can only be connected to one computer. Also, try going to google and searching for some drivers for your computer to download and install. Then try plugging your hard drive in again.
Dec 28, 2007 | FireLite (USBFLB80) Hard Drive
External hard drive
Check your device manager for any errors or conflicts.
Dec 16, 2007 | SmartDisk FireLite 40 GB Hard Drive
Smartdisk firelite won't be recognized on desktop-will on laptop
Jul 30, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
126 people viewed this question
David Payne
David Payne
