Question about Motorola Mobility RAZR V3
Phone wont shut off
Light on phone stays one even when its closed, and causes the battery to go dead in a couple of hours.
You might want to check your display settings. If it says backlight always on, change it to 10, 30, or 50 seconds and it should start turning itself off.
Posted on Aug 07, 2007
  • 28 Answers
Sounds like water damage or keypad bad.
Posted on Aug 01, 2007
SOURCE:
Why does my wifi turns on and off will not stay on or even light up green goes straight back t off
Sounds like ya battery's dying/dead. Replace it with new one - ya won't know yourself! :) WiFi is on and off cause the power saver kicks in and turns everything off.
Oct 29, 2017 | Samsung Galaxy S III S3 GT-i9300 16GB...
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
Hi i have a 8220 and red light is blinking on charging. I have checked very possible thing even the charger but cant get around pls help! thanks
Please don't worry this is caused because of various reasons.The lights explains what could be the problem
Orange and Yellow lights mean no defects in the mobile.Orange is phone battery is very low.Yellow is for boot up..
Red light means-You have power management problem.
You have to understand why it is being caused..
1)Due to dead battery.The phone will charge but you phone battery will not get charged it acts like it is getting charged.Behind the scene it cant store the charge.
2)Due to charger is not working properly no charge in the battery.
So you have replace this accordingly..
Please try this some time phone booting may be stopped,
This is not a solution when the battery is dead or fully down....
Sometimes The boot cycle of the phone is stopped.You have to start it.Remove the battery and place it again and press the red 'end' button continuously until the red light flashing stays on.Press green button' call' button and hold the red button...Now press these two buttons alternatively until you see hour glass symbol.Now when you see hour glass wait and see the phone booting....
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Mower battery keeps going dead. New battery, new ignition switch, dead in two days. My hour meter stays on even when the ignition is off, so I unplugged it, no help.
There should be a battery relay between the battery and the ignition switch. This relay activates by the keyswitch supplying a feed back to relay while in the on position, causing the relay to latch and powering up the entire electrical system. Chances are this relay has failed in the closed position causing the fuel solenoid and start relay to have power all the time, which will drain the battery in a day or two. A quick fix is to install a disconnect switch on the negative side of the battery which you can shut off when you are done with the machine. Hope this helps.
Jan 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Phone charged for hours but will not start up. it did start a couple of days ago but now wont start even when connected to charger.
battery might b damaged replace it..........if still it wont work...........and not showimg even a single light glow.........then you phone is dead
Nov 19, 2009 | Nokia 6700 Classic Cell Phone
Sanyo 6600 fully charged battery but wont turn on
just simply take the battery out and the phone will shut off. You will not lose any contacts or other memory as long as the phone is on idle
Aug 01, 2008 | Sanyo Katana SCP-6600 Cellular Phone
Battery life under 5 hours
have you let the battery go totally flat as this is recomended to do every couple of months because if you dont let the battery go totally flat this stops the battery from full recharging and will cause bad cells in the batt so i would let hte battery totally flat till it wont even light phone up then fully charge for 16 hours see if this improves the battery if not then the charger is probably over heating and cutting off so you could replace the charge hope this is some help to you
Nov 19, 2007 | Samsung SGH-D900 Cellular Phone
Motorola RAZR V3
the mainboard is gone and have to either be replaced or taken to a mobile service center close to you and hvae them use special equipment to revive it.
Aug 28, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
147 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
