Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Briggs & Stratton Vanguard V-Twin Vertical OHV Engine 16hp
    Problem Solver:
  • 5 Answers
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Posted on Feb 05, 2013
3 Suggested Answers
  • 395 Answers
SOURCE: Ok i have a problem
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Posted on Sep 22, 2010
  • 13 Answers
SOURCE: 23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Posted on Apr 09, 2012
Crankcase is full of fuel
Lacy:
The float and needle valve in your carburetor are not working as they should. The float should force the needle valve into the carburetor body to stop the flow of gas when the float bowl is full. When the float and needle valve do not work as they should, the gasoline keeps flowing into the float bowl and into the carburetor, and into the cylinder where it flows past the piston rings and into the crank case.
The carburetor needs to be removed and cleaned.
May 15, 2015 | Briggs & Stratton Briggs Stratton Vanguard...
Spark plugs foul immediately
Fouled plugs may be caused by oil leaking into the cylinder. Does it smoke when running (cold), are you using up the crank oil. Black smoke is excess gas comsumption, blue smoke is oil burning. If your plug is fouled with black carbon, you are most likely running to rich.
Apr 07, 2014 | Briggs & Stratton Briggs Stratton Vanguard...
Running poorly with oily plugs
broke oil rings from moisture getting in one cyclinder
Oct 24, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton vanguard 16 hp v-twin starter replacement
It most Likely is located under the engine cover..it mount just below the flywheel. Good luck
Apr 11, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 14 hp vanguard that wont run because its not getting fuel,,I have replaced the lines,fuel filter and tonight replaced the pump,,all sugessted by grasshopper tech,,also replaced the tube going down...
The fuel pump works off vacuum pulses off the crankshaft. More than likely the carburetor needs to be removed and cleaned out. This is a common problem with some Briggs engines.
Oct 11, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
16 h v-tech briggs-stratton is blowing oil into carburator, what could cause this problem and possable solutions
see if the oils coming out of the rubber hose by the air cleaner ,if it is it could be the pcv valve the rubber hose is connected to. order could be too much oil in the engine, sometimes the carburetor will flood the crankcase with gas , you have to rebuild the carburetor and change the oil.
Feb 18, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
Valve clearance?
The Briggs & Stratton website should be able to provide this information.
Aug 30, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
397 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Randy Schumann
Randy Schumann
Bill Boyd
nirodacyar
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
