Question about Motorola Mobility E51 MD7161-3 Quad Cordless Phone
Motorola md7161 keyboard not working
The phones are about a year old one phone started to not work, like you would have to push really hard to get it to dial now its all three handsets. they work sometime and other days not at all.
  • dzoo Apr 09, 2009
    I am having the exact same problem. My phone is about 1.5 years old and I can't even use on handset because I have to have a pen or pencil to push really hard on the keys to make it work, especially the on/off buttons.
I know you may not have experience in taking apart the handset or small electronic repair but, it is actually very easy to do. I just bought the same phone set from goodwill for $6.99. The set looks great and actually almost in new condition.
However, I had the same problem with just one handset so, I figured it out so, my set would work properly and now after I fixed it, I have no problems and every handset works great.
Follow these instructions step by step and I assure you it will work again like new.
Step 1.) Take the battery cover off on the back of the handset and pull the cord out carefully from the battery wire to where it connects to.
Step 2.) Unscre the two screws that you see inside. Then, carefully seperate the front cover from the inside of the phone to gain access to the inside of the phone so, you will have access to the 3 small screws that will seperate the circuit board to gain access to the keyboard.
Step 3.) After removing the circuit board and taking out the keyboard and rubber keyboard pad. Carefully wipe all of the buttoms very rigously with an alcohol wipe pad and you will start to notice some plastice film start to come off. This is what you want to remove beacuse, somehow it causes those keys to stick.
Step 5.) After wipeing them clean and reinserting the pad to the cover, the screws in the holes, aliging everything back together and snapping the cover back on, screwing the 2 screws back in and replacing the battery and cover. Test it and you will se that it works just like it did when the phone was brand new.
Hope it worked for you like it did for me and good luck. :)
Posted on Aug 15, 2009
What does A mean
For Baby/Home/Pet Monitors, Cordless/Corded Phones, Digital Photo Frames
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Corded/Cordless Phone email)
Motorola Support
Jun 23, 2014 | Motorola Mobility E51 MD7161-3 Quad...
Message softkey not showing messages
i think it is just a normal try using soft key with other feature if your phone allows to do so and if it works then simply change it to message key again then try else try factory resetting function it is there in your phone
Nov 03, 2013 | Motorola Mobility E51 MD7161-3 Quad...
My "a" button on the
THello this a problem phone. If the button is push in pop it out by lifting the button slightly. Now if this doen't work get the phone replace at your nearest verizon corporate store. If you need futher assistance call the customer service or warrany number on the phone.they will let you know all your options with this phone hope this information helps
Nov 06, 2010 | Motorola Mobility Rival A455 Cell Phone
Home phone not working
I just had the same problem. I unplugged the base and took the batteries out of all of the phones, waited 30 secs and then plugged the base back in and installed the batteries.
Apr 03, 2009 | Motorola Mobility E51 MD7161-3 Quad...
Phone phones parallel is on how do i shut it off
Unplug base unit overnight.
This will make the phones lose their charge.
In the morning just recharge phones again and everything will be back to normal.
Worked great for me!
Nov 18, 2008 | Motorola Mobility E51 MD7161-3 Quad...
MD 7161-3 Motorola phone
Hi
I have a Motorola D212 handset that is locked - I cant find the instruction book
can anyone help me unlock it please?
Oct 08, 2008 | Motorola Mobility E51 MD7161-3 Quad...
MD7161-3 - "A" on dislpay screen
You have seleced "Announce Only" mode (that is what the A means).
Sep 13, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Phone has error and stopped working
I had the same problem.....remove the batteries from all the phones...ensure the entire base is totally "dead"......and first put batteries to the base and switch ON the base....and then do the same for the extra handsets......hope tht works for you.....it worked for me!!
Oct 12, 2007 | Motorola Mobility E51 MD7161-2 Twin...
Motorola MD7161-2 owners manual
I found your manual for you. Hope this helps. http://broadband.motorola.com/consumers/products/MD7161/downloads/MD7161_User_Guide.pdf
Jun 24, 2007 | Motorola Mobility E51 MD7161-2 Twin...
Open Questions:
Handset reset / re-registration problem Motorola E51 MD7161-3 5.8 GHz Quad Cordless Phone (base unit with 3 handsets) no longer detecting handsets. The handsets suddenly stopped working and continuously displayed "SEARCHING" and/or "CHARGING". Attempts to reset and de-register / re-register as suggested by Motorola's Online Tech Support barely succeeded only for a while but ultimately failed. De-registration resulted in the handsets all displaying "ENTER BASE ID" continuously despite repeated entry of the correct Base ID. The problem seems to be in the Base unit's recognition circuitry because the message answering system still works fine, handsets are lit up o.k., keypads work normally, etc. In fact, one of the handsets was detected and worked for a while after persistently entering the base ID within a 2-day period. Then another handset was detected and worked briefly after another 2 days of persistent entry of the base ID. However, once the AC power and handset batteries were removed in an attempt to relocate the system to see if that would help then all handsets just display "ENTER BASE ID" continuously. The message answering system still works as usual without any problems, though. I really would like to get this system working again because it's got just the features I need. However, if all else fails, then I am looking at online reviews of the new Panasonic DECT 6.0 KX-TG9332 or KX-TG8232B and will consider one as a replacement. Can you offer any new solution for the Motorola E51 MD7161-3 problem? If none, have you reviewed the new Panasonic DECT 6.0 KX-TG9332 or KX-TG8232B yet and would you recommend either one?
Apr 02, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Motorola Mobility E51 MD7161-3 Quad Cordless Phone Logo
346 people viewed this question
Top Motorola Mobility Lands Phones Experts
john h
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
