Question about Frigidare Kitchen Ranges
My frigidare Gallery slide in range shows code F1 and licked what does this code mean?
Shows F1 and orange letters 'locked' and continues to beep
    Top Expert:
  • Frigidare Master
  • 9,472 Answers
What is the model number?
Posted on Jan 24, 2013
  • Paul Obert Jan 25, 2013
    model FES367CESD SERNO NF10224026
  • Richard Roth
    Richard Roth Jan 25, 2013
    F1 error, That's the Electronic Control Board that will need to be replaced. The plastic housing holds moisture in from cooking and takes out the microprocessor on the board. Here is the part you need to order.http://bit.ly/VwSyJU All parts come with a 365 day, any part, any reason return policy.
vest6
  • 196 Answers
SOURCE: F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Posted on Dec 30, 2007
aborcass
  • 2651 Answers
SOURCE: maytag electric range shows F1 error message and beeps
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Posted on Apr 08, 2008
  • 38 Answers
SOURCE: Cancelled self-clean, F9 code came up, door lock light flashing, can't use oven
HI,
your model number confirms that your range was manufactured by WCI (Frigidaire). although this doesn't help you now, it may help if parts are needed.
now, there is an indepth guide online to fixing this common problem and I would like you to go through it and see if it helps you solve your problem.
http://www.applianceaid.com/clean-lock.html
If you have found this site previously then I apologise, if you still need help, by all means post again and someone more qualified may help.
Hope this is of use to you ;)
Phil
Posted on Oct 28, 2008
  • 4 Answers
SOURCE: My Kenmore range model C970-628091 keeps beeping and flashing an F1 or F3 error code
Fridgetech is right. It's the temperature sensor. I had the same problem, but I was getting the F3 and F2 errors when attempting to preheat the oven.
A R Marshall said that he replaced the sensor but he still got the same F3 error. That happened to me too! It worked for a few weeks, then it began to malfunction again. It finally started showing preheated as soon as the oven was turned on, but never heated at all. One night at 3AM, the error code and beeper went off while we were sleeping! That happened on several occasions at various times of day, and it was necessary to kill the power to stop it. The power could then be restored and the error would stop.
Ours is a Hotpoint range (made by GE). It's my understanding that most ranges have the same or similar error codes.
The sensor was $85.00 at the parts store, but I got it on line for about $60.00 including shipping. The instructions said to strip the wires and then twist them together with wire nuts. But the new sensor had a plug that fit so I used it, and it worked for a short while.
As I looked through the problems and possible solutions, someone said look for burnt wires. So I opened it up and looked but there was nothing like that. Then I remembered the instructions that said to hard wire, so I examined the plug which seemed to have one short wire inside. I plugged it back in and tested with the same negative results. Now suspecting the plug I cut off both sides, stripped the wires and hard wired using two small wire nuts. It immediatly began working normally!
Something is wrong with the plug connector.
Try cutting out the plug and hard wiring before ordering a new part. But if you need a new part, eliminate the plug!
May God bless you and keep you safe!
Posted on Jan 22, 2009
  • 13 Answers
SOURCE: Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Posted on Aug 24, 2009
What does code F1 mean for a frigidare electrolux 316233852
Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad. Hope this helps please post solved if it does.
May 31, 2014 | Kitchen Ranges
I have a frigidare electric stove. The oven got
Hi
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Oct 01, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
2006 Frigidare Gallery Series 7G61704301 dosn t work
Did you have a power surge? Try unplugging the unit for 10 min and plug back in to reboot the curcuit board. If letters and numbers are being displayed it usually means the board is confused or fried.....
May 06, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
Jul 12, 2008 | Kitchen Ranges
F1 - oven will not turn on
You can try turning the power off for a couple minutes then back on but this is typically caused by a stuck key or a faulty control board. Either way you're looking at needing a new control board.
Hope this helps.
Dec 20, 2007 | Frigidaire Gallery GLEFM397DS Electric...
Code F1
jry, F1 code for the posted model number means the element relay energized when it shouldn't of. Some one has to check the J-2 harness on the board. Reseat it. If that checks ok, you will have to replace the power relay board. Catriver...post back.
Oct 08, 2006 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
82 people viewed this question
Top Frigidare Kitchen Ranges Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Frigidare Kitchen Range Expert? Answer questions, earn points and help others
