How to get rid of the blurry screen on my tv?
  • 3,904 Answers
My guess without further information is that you are bringing a digital signal into an analog TV withouth the proper scan converter. Let me know how this is feeding in and what components or equipment the signal is going through before it gets to the TV.
Posted on Jan 24, 2013
Dark Screen
It sounds like a back-light problem. Check all the CCFL back-lights.
May 08, 2013 | Samsung LN52a750R1FXZA
Blue line, blue out of sinc along botttom 1/4 of tv
If this is a Rear Projection T.V, your CRT is going bad. You can take the front cover off and make slight adjustments on the blue screen control to get rid of any lines, as far as the blurriness of blue, that part is 500 dollars to fix. The most you can do is just get rid of the lines. There's a black box. Make sure you are very gentle with your adjustments. Just turn it back to how it was if the screen shuts off. I recommend turning down the brightness of the T.V. before you do this repair.
Jun 18, 2011 | Panasonic Televison & Video
42" sony projection with blurry picture
Remove front bottm panel and behind it should be the Focus/Screen control block replace it.
Mats 1-800-628-1118
May 09, 2010 | Sony KP-51HW40 51" Rear Projection...
How to get rid of bluury pics
You need to configure the setting of the pictures, by removing it from blur to either sharp, soft or something else, click on the menu button of your camera to start the settings. The problem is as result of the settings you give your camera.
Sep 21, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Elmo slide to video projector
check the resolution. is your tv hd? the projector may not be.
Aug 20, 2008 | Elmo Projectors TRS-35XG 35mm 80 Slides...
RCA 36
I got an RCA 27" TV from someone who had moved it to another room but found it was "blurry" after moving it. I brought it home and tried all the suggestions I had found online but it was still blurry. I looked at the back of the TV and found 2 tiny knobs on the right (from the back view) which I began to fiddle with while looking at the screen. It fixed the blurriness immediately! I now have a beautiful screen.
Apr 30, 2008 | Toshiba 36A40 36" TV
Picture very blurry with lines going accross screen
hi gud day! your problem has a solution. Just try to fix your tv from blurry picture. Pull the socket at hte back of the picture tube. remove the socket from pcb(printed circuit board) de solder the pins. then after that, if you see a 2 metal formed like a small mountain facing each other, try to clean those remove the rust (green color) using sander or any material you can use, just avoid using oil on that bcause it is sparking. then try to install it again and try to turn on your tv. if still not working replace that socket with a new one. you can buy it at any electronic supply store. and re install then on it again.. surely it will fix your tv without expensive components.
be sure unplugging the tv from ac souce before disassimbling...
thanks,
janex
Mar 31, 2008 | Sony KP-61HS10 61" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Blurry tv
Sounds like theres a leaky capacitor in the screen drive circuit. I have seen this problem also be a gassy crt but was able to clean off the grids of the CRT with a crt/rejuvinator. It happens because of low emmissions in the tube and when white is on thats a mix of all the colors, so the tube works harder. I bet when you whatch a movie and the scene changes suddenly to a white or brite scene the pic looks a little washed out. If this is not the case then I aggree with the Pravin and try it on another TV just to be sure .. This is not a repair for a consumer to do, though however it is only a three year old set you stated, so there should be life left in the tube, so im kinda thinking a capacitor is bad. Seek out a yechnician to check this out for you as a TV is not a place to see it you can fix it or to exoeeriment with. Good Luck
Jul 26, 2006 | Toshiba 36A40 36" TV
Televison & Video Logo
Top Televison & Video Experts
