Question about Digitrex DV24B DVD Player Bundle with 10 Free Movies
Says no disc
Only been used for 2 weeks , i bought it for my kids for christmas and now it keeps saying "no disc" and will not play any dvd i put in it
Technika tv/dvd the dvd is only in black and white and wont play the discs
you can try using a DVD cleaner disk on your unit, try several times to make cretin it is clean then try your DVD`s again, if the unit was stored in a damp area this may be a problem, DVD players can be finicky due to this, there may also be a manufacturing defect in the unit that made it fail prematurely.
Jan 09, 2012 | Televison & Video
When you put in a dvd it says its loading, then it comes up no disc, I've used it on 2 different tv sets, different dvds, won't work. Whats wrong with it, problem not listed in the booklet. This is just...
Hi, This tell you, either your lens was defective or your disc is not compatible to your player. Please use disc that you know working good on your player and play. If still fail, we have been narrow down the problem now i.e your player lens. Please get it cleaned with disc lens cleaner and retry your player, If fail again, you need to replace the lens.
Jan 18, 2011 | TruTech DV288B3 DVD Player
I have a memorex 700MB dvd/cd , i made a video for my family for christmas and ever type i press burn it says disc type mismatch... i need help! please.
You need to use a DVD+R disc or a DVD-R disc to burn a video. It sounds as if you have made a DVD type video and put a CD-R in the slot and your burning software is detecting that and refusing to put the data on the disc, knowing that it wouldn't play on a DVD player.
Look at the front of your dvd drive - if it has a "DVD" symbol with an oblong disc below it and says "-R -RW" then you need to use a DVD-R disc. If it has a symbol of a big "RW" then you need a DVD+R disc. If it has both, then you should be able to use either one.
Dec 18, 2010 | Computers & Internet
MY PIONEER DVD RECORDER WILL NOT RECORD BUT PLAYS
hi have you tried to format the discs this sometimes work check your manual and it should tell you how to format
Dec 15, 2008 | Televison & Video
Rock band guitar light blinks like there is a short.this was bought a week ago.
being because getting this gift was for a good reason I would take it back asap, being that it is no longer christmas people are taking back gifts due to them being gifts and no receipt so they will not give you a hard time so please take it back.
I lost my dad a little time ago and I bought it as well with some others and mine is not doing that so do it before it is to late. If you have receipt and it is not 30 days old then take it but if it is 30 days old then go to the store and let them know that it was a gift and you would just like to trade it for another one. they will give you no problems
Nikki2913
Oct 22, 2008 | Video Game Consoles & Games
Polaroid PDM-0711 DVD player won't play DVD's but still plays CD's
I've got the same problem, I turn my player on it's side until it reads the disc. more of a band-aid solution.
Mar 28, 2008 | Polaroid 7'' Portable DVD Player
Mintek 1050 dvd player
Sounds like something may be stuck inside the unit. If there is no warranty left, UNPLUG the device from the mains, undo the 2 or 4 screws on the sides of the unit, lift off the lid and just look to see if there is a foreign object inside or a DVD,(if at some point one of the kids put 2 Discs in and closed it, one of them could have got pushed over the top of the drive and got jammed), remove it and put the lid back on. Just make sure you don't touch or fiddle with any thing inside as not to damage it further.
Another possibility is that something is stuck to laser lens which you will only be able to see if you take the lid off.
DANGER WARNING do not take the lid off in the same room as the kids, or they WILL do it themselves, when you are not about.
Feb 17, 2008 | Televison & Video
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Digitrex DV24B DVD Player Bundle with 10 Free Movies Logo
90 people viewed this question
Top Digitrex Televison & Video Experts
Electro Med Services...
Are you a Digitrex Televison and Video Expert? Answer questions, earn points and help others
