Question about HP Photosmart 945 Digital Camera
Red light flashes and LCD turns off and on
When I turn the camera on it just flashes a red light and the LCD screen turns on and off and on and off continually. I have tried resetting by leaving the batteries out for more than ten minutes but that doesn't seem to do anything, anyone have any suggestions? thanks
  • susan flock Jul 24, 2007
    How would I fix that problem then? Which part needs to be replaced?
  • susan flock Jul 29, 2007
    The problem is definitly NOT the batteries. I have tried several dozen different sets of batteries that all work in other digital cameras and have had no luck making this camera stop flashing red. The LCD screen does flash off and on as well. I appreciate the help so far, if anyone has any other suggestions I would definitly appreciate them! Thanks
  • 3 Answers
A guy named David was redoing the bathrooms in my house. He likes to take pictures of his work, and when he went to take final pics, his 945 started doing this. He tried 2 different sets (set=4 batteries that the camera needs) of standard Energizers, and got this error. We tried my Energizer rechargeable NiMH batteries (2500mAh each) and it worked again.
Posted on May 09, 2008
I have had a HP Photosmart 945 for a few years now. A few days ago was the first time I saw my camera experience the problem described above. I thought something is wrong with the on-bard logic.
Replacing my batteries (4x2300mAh NiMH AAs) with four other freshly charged batteries of the same kind didn't fix it. The camera's LCD kept flashing on and off for almost an hour until my family got tired of it and turned it off by removing the batteries.
I just replaced the rechargeable batteries with four regular alkaline batteries and now suddenly it works. Go figure.
The moral is that changing the batteries sometimes helps. When it works, it will get your camera going for a while. The problem, however, doesn't seem to be battery-related or I would have seen it a long time ago with smaller-capacity batteries like alkaline AAs. Something is very wrong with the camera itself, that much is clear.
Best-case scenario now is that I have an unreliable camera that can give out at any moment. For example today it died in mid-shot and almost spoiled a family event. For me the solution was "get a non-HP camera".
I hope this helps someone out there.
Posted on Dec 30, 2007
  • 624 Answers
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Posted on Jul 29, 2007
Changing batteries did the trick here. Weird problem though, we used the same rechargeable batteries all the time and suddenly this error. The batteries do work in other machines.
Posted on Jul 01, 2008
This happened to my HP Photosmart 945xi camera and the problem ended up being bad batteries. When I reset the camera and replaced it with new rechargeable batteries, all was well! I hope this helps.
Posted on Jul 28, 2007
    Problem Solver:
  • 32 Answers
This problem relates to internal circuit Sangita
Posted on Jul 24, 2007
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
LCD SCREEN WILL NOT TURN ON RED LIGHT FLASHING
what bank in p.a. can i open a checking account thats wont hold it against me if i owe another bank money?
Oct 04, 2009 | LG Televison & Video
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Red power light flashing on and off
the same thing happens to me! idk how to fix it
May 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Turning off after taking a picture with a flash
Sorry but that is just because the flash is recharging.. It turns the screen off so it can charge the flash faster.. No worries it works fine :)
Jan 24, 2008 | Nikon Coolpix 4600 Digital Camera
Camera turns off
the red symbol is the erasure prevention slider on the tape. check it's not on or push the slider on and off prevention. this should fix the red symbol, you might have to do it a couple of times before it works. not sure what F14 is can't find it in the manual. try the solution here. if it still turns off after a few seconds i have another way to fix the power.
Nov 04, 2007 | Panasonic NV-DS65 Mini DV Digital...
The colour on the EVF and LCD is pretty pink and nearly red
Yes it is. I believe Panasonic knows that the built in flash casts a very blue tint so they set the flash WB to very red to compensate. Therefore before the flash is triggered as when you watch the LCD. Some threads here even suggested adjust the WB further 2 knots to the red manually (press " up" a few times on the 4-way button to have better skin tone. Try it. The setting stays even when you turn off the camera.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
HP Photosmart 945 Digital Camera Logo
341 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
