Question about Pioneer DEH-P6800MP CD Player
DEH-P790BT The face plate when connected doesn't work at all. I tried resetting the face plate, But still nothing
  • 277 Answers
SOURCE: volume knob replacement deh-p760mp
hi if it s the right knob then it should fit pull out the old 1 from the device slowly.... soo if there is some kind of a spring or a spcial place that the spring was then you can see where it was and the install will be easyier take the new 1 hook the spring at its place (you can use the old 1 if its still in place and push to its place, adjust the slots inside the knob to the stem make sure that it sits still and working good good luck
Posted on Mar 27, 2006
Eagleeyes
  • 199 Answers
SOURCE: Ribbon cable between the face plate and mother board need part #
www.carradiospares.co.uk
mark
Posted on Nov 25, 2008
  • 323 Answers
SOURCE: face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Posted on Jun 11, 2009
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
Pioneer deh p790bt display only works when open and goes out when faceplate is closed. everything works but no display.
The ribbon cable is bad. This is easily repairable. I think Best Buy still does them or call your local electronics repair shop.
Oct 11, 2013 | Pioneer DEH-P790BT
Radio works but face plate shows nothing
You have two possibilities. You can try cleaning the contacts on the back of the radio and on the subpanel with qtips and rubbing alcohol or a pencil eraser. If that doesn't work, you may have bad solder connections on some surface mount resistors inside of the radio. If you are good at soldering they should be on the right front of the radio, you will have to remove the cd mechanism to get to them.
Mar 14, 2012 | Kenwood KDC-MP4028 CD Player
My face plate is frozen. The cd player works but nothing else what could be the problem.
First thing that I would try is to reset the radio. To do this, you would want to press the reset button (located behind the faceplate) using a bent paperclip or a ball-point pen. If this type of reset (soft reset) doesn't work, then you want to disconnect constant power from the radio (hard reset). This can be done by removing the power fuse for the radio or disconnecting the negative terminal of the car battery for about 15 seconds.
Start with those two methods. Beyond that, you may have a bad faceplate and/or a bad unit and it would need to be sent to Pioneer Electronics or an electronics repair technician. For repair estimates, I recommend visiting an authorized Pioneer retailer in your area.
Nov 17, 2011 | Pioneer DEH-P3500 CD Player
Freezes while i press open
first check all of your power and ground connections and be sure your battery is good then try the small reset button on the front face. if that does not work you may need a new flexible ribbon cable that you can find on ebay cheap.
Nov 25, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh-p840mp
THERE IS A RIBBON CABLE THAT CONNECTS THE FACE PLATES TO THE RADIO THAT NEEDS TO BE REPLACED
May 13, 2008 | Pioneer DEH-P840MP CD Player
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
Display
go into your tools menu by pressing the center of the multi knob.(the volume control knob) turn same knob to bring up the entertainment field, press center of knob to set then turn till you get to the prompt about alternating screen. switch to no. done.
Apr 06, 2008 | Pioneer DEH-P790BT
Connecting XM radio to my unit.
You have to tell your XM radio receiver what station to send the FM signal then you tune your radio to that station. Thats how my model worked when i used it.
Feb 01, 2008 | Pioneer DEH-P790BT
Pioneer DEH-P6800MP CD Player Logo
37 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
