Question about Kodak EasyShare C160 Digital Camera
Not reconizing my camera properties
The scanner/camera wizard will not recognoze this camera
  • cmlrusty
    cmlrusty Jan 24, 2013
    how can i fix this problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Jan 24, 2013
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Sep 17, 2013 | Epson Perfection V500 Flatbed Scanner
    Brother control center 4 won't open on my computer
    This may help others with scanning issues:
    I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
    The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
    Hope this helps somebody else as frustrated as I was.
    Apr 17, 2013 | Brother DCP Office Equipment & Supplies
    Brother mfc-j6510dw will not scan
    I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
    Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
    I have Acer 640P Scaner, if does'nt work with
    You need to install the Mirascan driver first and then install the scanner manually.
    1.You need to download the MiraScan v3.424. ftp://12.145.38.159/scanner/drivers/parallel/mirascanv3424p.zip
    2. Unzip and install the MiraScan driver and it will prompt for an add scanner wizard.
    3. Proceed with add an imaging device.
    4. Then the Scanner and Camera Installation Wizard comes up. Click Next at the bottom.
    5. On Scanner and Camera Installation Wizard,You need to select the option where you can choose a "Manufacturer". Locate EPPSCANNER. For the "Model" option, select color flatbedscanner. Proceed with the final steps of the wizard.
    6. Restart your computer and then test scanner.
    Oct 17, 2009 | Acer ScanPrisa 640P Flatbed Scanner
    Lexmark X5340 - All in One Printer/Scanner/Copier/Fax
    Please follow the steps given below to add the scanner using Scanner and Camera wizard.
    1. Plug your scanner into your computer.
    2. If your scanner is "Plug and Play," the "Scanner and Camera Wizard" starts or double-click add device. Follow the instructions on your screen.
    Note:
    1. To open "Scanners and Cameras," click "Start," click "Control Panel," click "Printers and Other Hardware" and then click "Scanners and Cameras."
    2. If you have a "Plug and Play" scanner, Windows detects it and installs it automatically.
    3. If your scanner is not "Plug and Play," follow the installation instructions that came with the device.
    4. If your scanner is not listed in the "Scanner and Camera Installation Wizard," try to install it using device manager.
    5. After you install your scanner, you can test it.
    Oct 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
    My acer laptop crystal eye webcam is not working
    you can see your web cam wizard in my computer.
    Also you can see in scanner and camera wizard.go to control panel and then scanner and camera wizard.
    If you are not able to find camera then go to my computer property then hardware->device manager.
    Then check that your cam drivers is installed .
    Also try to uninstall cmaera then reinstall it then it works.
    If you haven't driver disk then you can downlaod driver from below link.
    click here
    click on above link then select your model and operating system then download camera driver then install.Then it works.
    Let me know if you need more assistance.
    Thanks.
    Oct 01, 2009 | Acer Aspire One PC Notebook
    Vista os loads software but wont reconize camera
    There might be compatibility issue. Try running the compatibility wizard in vista. You can start the wizard by typing compatibility wizard in windows Help and Support; it will display a link. Select your powershot software in the list of programs and choose XP in the compatibility mode.
    Jul 01, 2008 | Canon PowerShot A520 Digital Camera
    Won't recognize scanner when installed
    First, make sure your computer has been updated to at least Windows XP Service Pack 1....Service Pack 2 is even better. You can check this by right-clicking on my computer and selecting Properties from the menu. If you're using Service Pack 1 or earlier...it would be a good idea to run through the Windows Update process a few times.
    Try downloading a new Scan Wizard file from this page on the MicroTek web site. When you do the install, it should remove any previous drivers and clean things up.
    If this doesn't help, try to find the Windows Scanner and Camera Wizard...usually located under Start>All Programs>Accessories. It may work even if the MicroTek software doesn't.
    Good luck...and I hope this is helpful!
    Jan 13, 2008 | Microtek SCANMAKER 4850 Flatbed Scanner
    Open Questions:
    See all Kodak EasyShare C160 Digital Camera Questions
    Kodak EasyShare C160 Digital Camera Logo
    13 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
