Maytag mavt236aww works on delicate but not on normal. when in normal position the washer will fill up, but will not agitate or spin out or drain
  • Washing Mach... Master
  • 17,130 Answers
Possible that the controller unit is a suspect.Check the INLET flow , check the INLET valve, Check if water fills, If not there are errors in the program output and the controller could have memory issues.
Posted on Jan 24, 2013
  • 19 Answers
SOURCE: Maytag Performa washer Waterlevel/agitator problem
CHECK your stand pipe hasn't fell over (the one the drain hose goes to when emptying)If not,Either the pressure switch is broke or there is a hole or split in the pressure switch rubber hose.This switch stops the water when it reaches required level.
Posted on Aug 16, 2007
  • 319 Answers
SOURCE: maytag washer, lat9606aae only works in delicate cycle and hand washable
Replace it
Posted on Jan 04, 2008
My girlfriend's LAT9704 had the EXACT same problem. I replaced the timer module an now it works in all cycles. Part wasn't cheap though - $80
Posted on Apr 09, 2008
IFIXALL
  • 868 Answers
SOURCE: Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Posted on May 23, 2008
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Nov 02, 2015 | Washing Machines
My LAT9635AAE washer will only agitate on the delicate cycle. the timer goes thorugh the cycles on the other settings, but the agitatior will not move
You have a problem with the contacts in the timer and it will need to be replaced. Here is the part to order. To replace the timer remove the cover on the back of the console.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Aug 15, 2007 | Maytag Performa PAV2200
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
