Question about Vehicle Parts & Accessories
Locate the temp sensor on 2004 chevy impala - Vehicle Parts & Accessories
  • Vehicle Part... Master
  • 14,406 Answers
Here's a guide for your sensor.
Posted on Jan 24, 2013
    Genius:
  • 1,669 Answers
I hate to tell you but there is more than one! One is the outside air temperature located in the grill that gives (supposedly) the temperature of the outside air. The other one is the radiator water temperature sensor that is located on either the right or the left side of the cooling radiator for the engine mounted in a fixture welded to that side of the radiator (the one with the wire coming out of it).
Automatic transmission input shaft speed sensor
(440) Automatic Transmission Input Shaft Speed (A/T ISS) Sensor Assembly
Jul 02, 2014 | 2004 Chevrolet Impala
2004 Impala
Would check the sensor at the front of the car near front bumper or radiator support make sure it's plugged or not damaged.
Aug 22, 2012 | 2004 Chevrolet Chevrolet Impala
Why the check engine light comes on when it only cold outside in my 2004 chevy impala ss?
ur air intake temp sensor could be goin out.if u have a scanner it will read a -XX temp if its bad
Feb 12, 2012 | 2004 Chevrolet Impala
How much do front wheel bearing sensor run for a 2004 chevy impala
On the 2004 impala the ABS sensor comes attached to the wheel bearing hub assembly. the hub assembly is around 100 dollars. If you are referring to the wheel speed sensor it is around 25 dollars.
Jul 03, 2011 | 2004 Chevrolet Impala
2003 Chevy Impala, running hot. Changed fan shroud because cooling fan wouldn't turn on, switched out fan relays, no check engine light. Cooling fan still will not turn on.
Would turn the key on no need to start it and unplug the ect engine coolant temp sensor. If fans come on then suspect a faulty etc which may not turn on the engine light. Which engine is in the vehicle so I can help locate the ect which is usually by the thermostat housing.
Jun 12, 2011 | 2003 Chevrolet Impala
2006 chevy impala coolant temp sensor where is at on car
The coolant temp sensor located ( below the thermostat housing in the intake manifold )
hope this can help. good luck
Mar 26, 2010 | 2006 Chevrolet Impala
Temp Sensor
The temp sensor known as the engine coolant temp. sensor tells the computer if the engine is overheating and so forth and tells the injectors how much fuel to give the engine. The temp. sending unit is what controls what your guage reads. It sounds like you need the temp. sending unit. It located near the thermostat housing with a single pole connector.
Jun 18, 2008 | 2004 Chevrolet Impala
Vehicle Parts & Accessories Logo
229 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
