How to reset korjo padlock cl30 - Office Equipment & Supplies
I have a korjo boarding pass BPL2 and have forgotten combination and can't relock - am i able to reset
If it is open, it is a lot easier to find the combination than if it were closed! Unfortunately, I can't find an image of this lock to advise you. If it is a standard combination lock with a loop shackle, you put gentle pressure on the loop as you turn the top dial of numbers. When the loop drops in, write down the number, then without moving that dial start turning the second dial until the shackle drops in, write down that number. Do the same with cylinders 3 and 4.
Mar 16, 2016 | Locks & Locksmithing
How to enter service mode
Sorry my friend but i don't think CL30 has a service mode
Nov 30, 2012 | Xante CL30 HSE Laser Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Transfer belt error 356
there is what is called a etb electron static transfer belt in this system if that is what you are referring to then it will be a big cost to six. but if the etb belt ids warn then that might be why it's life was so short
May 15, 2010 | Xante CL30 HSE Laser Printer
I have the cl30. It prints fine except photos and
it's not a photographic print. even with thew best photo paper you will not have the best qualiy
May 13, 2010 | Xante CL30 HSE Laser Printer
Xante cl30
If the printer is still under warranty, and a new yellow drum doesn't fix the problem, or if you install a new drum and the problem returns, Xante should provide you with warranty support. This problem can be caused by a defective high voltage power supply, and that is not a user replaceable item.
May 02, 2008 | Xante CL30 HSE Laser Printer
Xante CL30 printing streak line in middle of the paper
make sure there is nothing on th belt of the unit
Oct 25, 2007 | Xante CL30 HSE Laser Printer
24 people viewed this question
jasbo
jasbo
