Wiring diagram for pci express motherboard mcp68sm-pm
Case connecters
  • 293 Answers
SOURCE: wiring
The user guide for the motherboard should have a full diagram for all the wiring you have. Here is the link: http://www.manualnguide.com/dl/8959/
Posted on Sep 12, 2008
Rubec
  • 42 Answers
SOURCE: ecs motherboard wiring diagram
You need to check if *********** board has the pinouts for external connctions, and if your case has the option for this. (Some do some don't) You can buy extra utility bays if your case doesn't.
Look in your manual for the MB and look for external USB and audio out connections.
If you need the manual goto: http://www.ecs.com.tw (Site is down at the mo, but try later)
Posted on May 11, 2008
vancer32
  • 31 Answers
SOURCE: Version of PCI Express
my motherboard has a PCI-E 1.0 it's an Asus Commando graphics is 9600GT which is PCI-E 2.0 and it runs fine till now no prob about that mate PCI-E 1.0 and 2.0 is backwards compatible so it should work fine make sure your graphics card is working @ x16 coz when I first plug my graphics it runs only @ x2 then I reset the bios and re-seat the graphics now fully functional x16 of PCI-E lanes.
Posted on Jun 09, 2008
gotgeek2
  • 565 Answers
SOURCE: instructions on atx case wiring to motherboard
Assuming that the computer is laying down on it's right side, and you are viewing the F panel (the front panel header) from the right side of the motherboard (the bottom of the computer), pin 1 is on the bottom left of the F panel, pin 2 is on the top left, pin 9 is on the lower right, and pin 10 is on the top right (no actual pin)...
1 HD_LED_P Hard disk LED (+) 2 FP PWR/SLP *MSG LED (+)
3 HD_LED_N Hard disk LED (-)
5 RST_SW_N Reset Switch (-)
7 RST_SW_P Reset Switch (+)
9 RSVD Reserved
4 FP PWR/SLP *MSG LED (-)
6 PWR_SW_P Power Switch (+)
8 PWR_SW_N Power Switch (-)
10 Key No pin
Usually the wires and the pins are color coded, (the colored ones being positive.) Sometimes the connections are written in very small abbreviations on the motherboard.
Posted on Jan 28, 2009
DickCanFixIt
  • 948 Answers
SOURCE: Hooking up case wires to motherboard: ECS M925
If you look at this picture, the pins on the motherboard should be on the far left below the brown slot and above the white connector. The pins on the board are marked with tiny white letters HDD, PWR, RST, SPKR. The USB connection on the board may require a separate header, I can't find a manual to see for sure.
Posted on Apr 04, 2009
MCP68SM-PM motherboard manual
que modelos de microprocesadores son compatibles con esta placa?... yo tengo amd 64 x2 4400+ y quisiera saber si podria ponerle alguno superior
Dec 19, 2013 | Packard Bell Computers & Internet
Is not Reading My Geforce GTX 260 Card
What do you mean connect wire to graphics card?
A) Computer is to be OFF when connecting a monitor cable.
B) Computer is to be OFF, and unplugged from power; when plugging the power cable from Power Supply, into it.
You are also supposed to be Following Anti-Static Precautions.
What Power Supply are you using?
Manufacturer name, and model number. Post back in a Comment.
Motherboard requires about 150 Watts by itself.
That isn't including what the Processor (CPU) needs, Ram Memory needs, optical drive/s need, computer case fans need; AND what the Nvidia GeForce GTX 260 graphics card needs.
It needs 225 Watts by itself.
(Manufacturers usually state around 500 Watts MINIMUM.
This is in reality based on a COMPLETE computer system, and NOT just the graphics card itself)
What do I base that the GTX 260 needs 225 Watts?
(I see that as the -> Maximum, though )
A PCI Express x16 expansion slot on a motherboard, is only capable of 75 Watts of power.
That is why the additional power cables were brought out.
The 6-pin PCI Express power cable that plugs into the GTX 260, is capable of an additional 75 Watts of power.
The Nvidia GeForce GTX 260 requires using TWO 6-pin PCI Express power cables
That means 150 Watts of additional power.
75 Watts + 150 Watts = 225 Watts
http://www.geforce.com/hardware/desktop-gpus/geforce-gtx-260/specifications
"Supplementary Power Connectors -> 6-pin x2"
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress
If you are using just one 6-pin PCI Express power cable, '
this = NO.
NOT enough power for the graphics card.
What will happen?
A) The PCI Express x16 slot connector oins, will burn
B) The gold plated contact pins on the bottom of the graphics card, will burn.
C) The connector on the graphics card, that the 6-pin PCI Express power cable plugs into, will burn.
D) The connector on the 6-pin PCI Express power cable will burn.
The graphics card will burn up.
Too little power.
IF, your Power Supply has enough power, and IF there are two 4-pin Peripheral power cables that aren't being used; you can use a 6-pin PCI Express power adapter cable.
Example of 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Example of 6-pin PCI Express power adapter cable, was shown in the Playtool link,
http://www.directron.com/pci03.html
(Connectors are white, and hard to see against white backdrop. You can enlarge all 3 views)
For additional questions please post in a Comment
Regards,
joecoolvette
Feb 23, 2013 | Gigabyte GA-M61PME-S2 Motherboard, AM2,...
Looking for advice on a video card. Would a radeon hd 5750 run on c51gm motherboard
1) You have a PCI Express x16 expansion slot, for a graphics card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135010
(Orange)
A) 1GigaByte of graphics memory which is GDDR3. (It is GDDR3, not DDR3; trust me)
B) 800MegaHertz Core Clock
C) 1600MHz Memory Clock
D) API's - DirectX 11
Open GL 4.1
Shader Model 5.0
2) The motherboard chipset is an Nvidia GeForce 6100 - Northbridge, and an Nvidia nForce 410 - Southbridge.
http://en.wikipedia.org/wiki/GeForce_6_Series#GeForce_6100_and_6150_series_chip_specifications
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_6_.286xxx.29_series
Nvidia GeForce 6100/nForce 410, came out 2005.
3) http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The Northbridge chip of the motherboard chipset, handles the Faster capabilities of a computer.
Processor (CPU), Ram Memory, and HIGH-speed graphics.
AGP technology, and PCI Express technology, ARE HIGH-speed graphics.
Using a PCI slot for a graphics card, or using Integrated Graphics; is NOT high speed graphics.
(As you can see in the Motherboard Diagram, the PCI bus is controlled by the Southbridge chip. The Southbridge chip handles the Slower capabilities of a computer.
Means anything connected to the PCI bus, such as a graphics card in a PCI expansion slot; is handled by the Southbridge chip.
Integrated graphics also )
4) PCI Express came out 2004.
Went from PCI Express 1.0 version to PCI Express 1.1 version.
In 2007 PCI Express went to the 2.0 version. PCI Express 2.0.
Your motherboard, IMHO, uses the PCI Express 1.1 technology.
This is why I recommend a graphics card based on the PCI Express 2.0 technology. (For one)
PCI Express 2.0 is Backward Compatible, with PCI Express 1.1
A little iffy if it's PCI Express 1.0
I have seen a lot of problems crop up with users trying to use a graphics card, based on the PCI Express 2.1 technology; on a motherboard based on the PCI Express 2.1 technology.
That's why I recommended PCI Express 2.0
PCI Express 3.0 is supposed to overcome that, (Use on a mobo with PCI-E 1.1), but I have no real world knowledge, (Hands on), and no input from the 'outside'. (Internet/world)
5) You need at least a 400 Watt power supply. Don't have at least a 400 Watt? Time to move up.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1147669&Sku=U12-41529
Regards,
joecoolvette
Nov 20, 2012 | ECS C51GM-M Motherboard
What graphics cards is best suited in my ecs 945gct-m2 v. 1.3 motherboard
That really depends on several things.
1. What is your power supply make & model? How many watts does it put out? What size power supply is recommended for the video card I want?
2. How big is your case? Do you have a lot of add-on cards already in the case? Will the ram slots get in the way of your PCI Express x16 slot?
3. How good id your cooling system inside your case? Does it have enough fans?
4. What slots can you use for graphics cards?
In your case you have :
1 x PCI Express x16 slot
1 x PCI Express x1 slot
2 x PCI slots
You can get a great deal on a graphics card from here when you determine what the answers are to those questions:
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=48&name=Desktop-Graphics-Cards&Order=PRICE
Jun 10, 2012 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
What is compatible graphic card for A740GM-M
Any PCI Express x16 or PCI Express v2.0 x16 card show work provided your power supply can handle it and that it's no too big for your case.
Jun 06, 2012 | EliteGroup ECS A740GM-M Motherboard -...
Need emachines T3304 motherboard connection diagram
The eMachines T3304 Desktop PC uses an FIC K8MC51G motherboard.
First International Computers { Inc}
http://www.e4allupgraders.info/dir1/motherboards/socket754/fick8mc51g.shtml
http://support.gateway.com/s//MOTHERBD/FIC/105554/105554nv.shtml
Click on Product Views, then on - M-Front Panel Connector
The plastic front of your eMachines is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as F_PANEL, or FP1.
Looking at the motherboard installed in the computer case, the Front Panel header is at the Bottom/Right.
http://support.gateway.com/s/MOTHERBD/FIC/105554/105554mvr4.shtml
The above link shows the pinout, of the Front Panel header.
(Note* The Front Panel header may not be Orange in color)
It is the Second header over from the bottom/right side.
The pins are numbered.
Starting on the TOP row, from the RIGHT side going towards the LEFT;
Pins 10, 8, 6, 4, and 2
Starting on the BOTTOM row, from the RIGHT side going towards the LEFT;
Pins 9, 7, 5, 3, and 1.
A) Pins 1 and 3 are for the HarDDrive Activity LED light.
The LED light that blinks when the harddrive is in use, or active.
Pin 1 is for the Positive ( + ) wire.
If the LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch (Button), IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. I believe if memory serves, that it is ONLY used by the factory.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire. ( + )
If the Power On LED light is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Pin 10 is N/C. Not Connected.
(Note it states - Key
It shows you where the pins are. What order they should be by the missing pin)
The FIC K8MC51G motherboard;
1) Has a Socket 754 processor socket.
AMD processors fit in this processor socket,
http://en.wikipedia.org/wiki/Socket_754
2) The motherboard chipset is an Nvidia C51.
It is part of the GeForce 6 series, and more specifically, the GeForce 6100 series,
Using this knowledge you can see what Processors are supported, and what Ram Memory is supported, (And how much)
AMD Sempron, or AMD Athlon 64 processors, with up to a 1000MHz Front Side Bus. (FSB) { That fit in a Socket 754 processor socket)
DDR Sdram ram memory that is 200MHz up to 400MHz.
(PC2100, or PC2700, {333MHz}, or PC3200)
{184-pins. 92 on each side}
OR,
DDR2 Sdram ram memory that is 400MegaHertz up to 1066MHz.
(PC2-3200, or PC2-4200/4300, or PC2-5300, or PC2-6400, or PC2-8500)
{240 pins. 120 on each side}
Your motherboard uses DDR Sdram. (184 pins. 92 on each side)
Maximum TOTAL Amount is 2GigaByte. (2GB)
Maximum Amount for EACH ram slot is 1GB.
3) Has one PCI-Express x16 slot for a PCI-Express graphics card.
The PCI-Express technology used for the motherboard is
PCI-Express 1.1
HOWEVER, you can use a PCI-Express graphics card that is based on the PCI-Express 2.0 technology.
PCI-Express 2.0 is Backward Compatible, with PCI-Express 1.1
You just will Not get the full capability of a PCI-Express 2.0 graphics card.
Will you notice? No
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 21, 2012 | Computers & Internet
Hi Is there a PCI Express slot on the motherboard MSI K9VGM-V I see 2 PCI slots and another white slot above is this for a PCI Video card THANKS
On your MSI K9VGM-V, you do have a PCI-Express x16 slot, which is used for most video cards now days. You can see the full slot diagram on the picture below.
The one for the video card is labeled: PCI Express x16 Slot
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | MSI K9VGM-V Motherboard
Describe your fujitsu scenic D i845GE -PM
The Fujitsu Siemens Scenic D i845 desktop computer, has an Intel 845GE motherboard chipset.
Primer:
Motherboard Chipset.
The Northbridge, and Southbridge chip, is the motherboard chipset.
Chipset, and Chip are slang terms for I.C.
Integrated Circuit.
Motherboard diagram showing the relation of the Northbridge, and Southbridge chip,
(CPU stands for Central Processing Unit, or for short - Processor)
The Northbridge chip handles the Processor, Ram Memory, and high-speed graphics.
(Such as AGP, or PCI Express. Not a graphics card inserted into a PCI slot, and not Integrated Graphics)
The Northbridge chip handles the faster capabilities of the computer.
The Southbridge chip handles the slower capabilities.
Such as anything inserted into a PCI slot, Integrated Graphics, IDE, SATA, and USB, to name a few.
http://en.wikipedia.org/wiki/Southbridge_%28computing%29
The Northbridge chip used on the Fujitsu Siemens Scenic D i845GE, is the Intel 82845GE
The Southbridge chip is the Intel ICH4.
Jun 02, 2010 | Fujitsu Siemens SCENIC W600 PC Desktop
Trying to find interal connectors 2-1 pin audio spdif on a emachine 1831-05. motherboard is mcp73vt-pm
It has been stated from my sources, that the ECS GF7050VT-M5 mobo, is the same as the ECS MCP73VT-PM, with a slight difference.
The difference being that the MCP73VT-PM mobo is based on the Micro-ATX form factor, and the GF7050VT-M5 is based on the ATX form factor.
[ Micro-ATX form factor size is 9.6 inches by 9.6 inches. 9.6 inches is approximately 9 and 9/16ths inches. It's also 244mm by 244mm.
ATX form factor is 12 inches by 9.6 inches. 305mm by 244mm ]
ECS MCP73VT-PM,
http://www.e4allupgraders.info/dir1/motherboards/socket775/ecsMCP73VT-PM.shtml
ECS GF7050VT-M5,
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=858&CategoryID=1&DetailName=Manual&MenuID=1&LanID=0
To the right of the subheading - Download, left-click on the server location nearest you.
[Taiwan, USA, Europe, China ]
This is a PDF file download. (Motherboard Manual) May take a few seconds before you see the first page, and additional time for the file to fully download.
Suggest you let the file download all the way, before looking through it.
I'm also looking at an ECS MCP73VT-PM on Ebay, as well as the PDF motherboard manual for the ECS GF7050VT-M5.
Motherboard oriented so that the Processor is to the top, ram memory slots to the right, and the orange PCI Express x16 slot to the bottom, the SP/DIF header on the GF7050VT-M5 is located to the left of the PCI Express slot.
From the poor view on the Ebay link, the MCP73VT-PM also seems to have the SP/DIF header in the same location, but clocked differently.
The header is clocked perpendicular to the orange PCI Express x16 slot, while on the GF7050VT-M5 the SP/DIF header is parallel to the PCI Express x16 slot.
The header is 4 pins long, with 1 pin not installed.
Pin 1 is marked on the motherboard.
Pin 1 is SP/DIF Digital Output
Pin 2 is +5VA ( 5 Volt analog power)
Pin 4 is Ground
There is no Pin 3.
Apr 06, 2010 | Computers & Internet
Computers & Internet Logo
237 people viewed this question
David Payne
David Payne
