Question about Astro 1998 98
Why the heater is not working at all? - Astro 1998 98
    Problem Solver:
  • 8 Answers
Under the dash on the right side, look for a plastic cover that runs along the bottom of the dash. Their about 8 or 10 screws holding it on, take the screws out and look to see if the vent flapper is stuck , if it is apply a little wd-40 and then try to work it back and forth to try to free it up. If this works, re install the cover and put the screws back in the holes to keep everything covered and safe from getting broken. Good Luck.Your Friend, davant1958@yahoo.com
Posted on Jan 24, 2013
2006 mini cooper heater is not working
mini cooper s heat not working - North American Motoring
www.northamericanmotoring.com/...2006/243158-mini-cooper-s-heat-n...
Jan 2, 2013 - mini cooper s heat not working R50/R53 :: Hatch Talk (2002-2006) ...Any way to determine if the heater core is clogged? And could it be ... Overheating issue / heater not working
Jan 18, 2012
No Heat!!!
Nov 5, 2011
2008 MC Heater Problem
Nov 2, 2008
Heater stops working at idle, Engine overheating light comes on at ...
Apr 10, 2008
More results from www.northamericanmotoring.com
MINI COOPER 07 heater blowing cold air-HELP - MINI Cooper Forum
www.mini2.com > ... > Second Generation Faults & Fixes
Mar 6, 2010 - I too have a 2007 Mini Cooper with heater problems. It now has 96,000 miles and I have just started having this problem. Heater will not blow out hot air bottom or top vents when ideling or low speeds .... Join Date: Nov 2006. Heating not working - mini one 02plate - MINI Cooper Forum
May 15, 2012
2002 Cooper S lukewarm heater - MINI Cooper Forum - Mini2.com
Oct 25, 2011
Problem with heater blower - and no resistor pack to be found ...
Mar 21, 2011
mini cooper 02 HEATER NOT WORKING? - MINI Cooper Forum
Jan 19, 2010
More results from www.mini2.com
Heat not working, MINI overheating! - Motoring Alliance :: MINI ...
www.motoringalliance.com > ... > 1st Generation MINI > Cooper S
Jan 12, 2016 | Mini Cars & Trucks
2000 ford taurus heater not working. What can be wrong?
It sounds very much like the heater control door (inside the heater box) is sticking in one position or the other. It's intended to direct air through either the AC's evaporator or the heater core, depending upon whether you want heat or cooling.
Assuming (highly likely) that the control door is vacuum-operated, you may have a vacuum leak anywhere from the engine to the heater box inside the passenger compartment, via the heater control unit.
Nov 18, 2014 | 2000 Ford Taurus
2007 Honda Odyssey front heater is not working, and the rear works fine
Depends on if the heater is working and the hot air is not going thru the vents, or the heater core is not hot.
Could be a faulty blend door under the dash.
Sep 21, 2012 | 2007 Honda Odyssey
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Cannot get the heater to work
CHECK SEE IF HEATER BLOWER MOTOR WORKING, REMOVE HEATER BLOWER MOTOR HOT WIRE HEATER BLOWER MOTOR SEE IF BLOWER MOTOR WORKING BLOWER MOTOR FAULTY OR YOU HAVE FAULTY WIRING AT BLOWER MOTOR AND RESISTOR.
Nov 05, 2011 | 1996 Mercury Grand Marquis
Vulcan wall heater needs full service, Fawkner VIC 3060
your fan controll thermostat in the heater is not working it needs to be replaced thanks from gilles
Mar 14, 2009 | Heating & Cooling
The heater still won't work after I changed the thermostat on my
Get a female garden hose adapter from the local hardware store. Disconnect the heater hose from behind the fan pulley and attach the hose connection. Disconnect the other heater hose behind the alternator, aim it towards the ground and flush water through the heater core. This worked on my truck.
Feb 12, 2009 | 1999 GMC Sonoma
Heater stopped working
The heater core has gone out and will need to be replaced
Dec 07, 2008 | 2002 Mazda Millenia
Astro 1998 98 Logo
Top Astro Car Audio & Video Experts
xxxxxx xxx
Are you an Astro Car Audio and Video Expert? Answer questions, earn points and help others
