Question about Whirlpool GS6NBEXR Side by Side Refrigerator
My whirlpool gold ice dispenser leaks water and creates icicles inside, what could this be?
My freezer shows signs of a water leak
  • Whirlpool Master
  • 2,328 Answers
Bad water valve or the ice maker is cracked,if the valve doesn't work correctly it can let to much water into the ice maker causing it to overflow or the ice maker has a crack in it and the water leaks out.
Posted on Nov 20, 2017
4 Suggested Answers
  • 1462 Answers
SOURCE: Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Posted on Nov 26, 2008
woodchuck789
  • 4070 Answers
SOURCE: whirlpool side by side e25pqxfw00 icemaker leaking water
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
If it's actually leaking from the ice mold, you can replace indivdivual parts of the ice maker on some models. Post your mokel number and we'll have a look.Find model number >http://www.appliancepartspros.com/modelnumber_locator.aspx
Posted on Sep 07, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Posted on Jul 12, 2012
Jul 11, 2012 | Whirlpool Refrigerators
Water leaking from whirlpool gold refrigerator
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No ice instead water dripping down into freezer making icicles
If you have icicles, where are they forming at? If on the front of the ice bucket, then look at the dispenser shoot door is closing all the way. The way to check that is to look into the shoot while holding a flash light (or bright light) up into the dispenser from the front side of door. You should see no light.
Now if you have ice buildup around the inside of bucket, mainly from the ice maker to the bucket then you either have an ice maker that is leaking water or you have a water valve that is not shutting off all the way. Suspect water valve if you have ice buildup within water inlet tube on top of ice maker. Frozen water within tube is good indication that water valve is leaking.
Look inside refrig side of refrig, usually located on right top side of wall, you will find a tag with model number and serial number. Need both to get you the right part number for ice maker or water valve.
Oct 08, 2009 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool Refrigerator water leak through Ice dispenser
You need to remove the ice maker and open the front carefully. It has small micro switches inside it and it sounds like one that opens the water control valve is stuck in the on position. Be careful not to loose the arm spring and how that goes back together as you take it apart. Sea Breeze
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
