Question about Whirlpool Dryers
How do test a gas dryer gas valve
Gas
  • Whirlpool Master
  • 2,365 Answers
If for leaks, use very soapy water and give a "bubbles " test.
Posted on Jan 24, 2013
Maytag Gas Neptune Dryer MDG5500AWW no heat
see this causes and fix it. God bless you
Dryer tumbles, but there is no heat
Sep 27, 2012 | Maytag Neptune MDE5500AY Electric Dryer
I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
Thank you for contacting fixya.com.
If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
Please get back to us if you have further query else please accept the suggestion.
Jun 15, 2011 | Dryers
Gas not firing
If gas coils read more than 2500 ohms they are bad, replace gas valve. See page 23
Mar 19, 2010 | Dryers
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool dryer gold not drying clothes
  • Check for proper air flow
  • Check the ignitor
  • Check gas jet
  • Test the gas valve coils
  • Check the flame sensor
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the temperature selector switch
  • Here is a website to aid with these tests
    http://www.acmehowto.com/howto/appliance/dryer/diaggdryer.php
    Nov 11, 2009 | Whirlpool GEW9250 Electric Dryer
    Gas Dryer igniter glows but does not ignite
    If the igniter goes on but only cycles off you have a bad solenoid coil on the valve you can pick them up as a set at a local parts supply shouldn't be more than $25
    Sep 04, 2009 | GE DDC4500S Gas Commercial Dryer
    Dryer motor works but will not heat. Dryer is gas
    First, check to see that the ignitor is operating properly. It should glow orange if it is heating up. If the ignitor is ok, then look at the gas valve coils. These coils are right above the gas valves and when these solenoids are energized, they open the gas valves. If the coils are faulty, it cannot open the valves and so the gas cannot ignite. If they are faulty, and due to the difficulty in testing them, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
    Aug 02, 2009 | Maytag MGDZ400TQ Gas Dryer
    Have a gas dryer,it works but it won't get hot
    Hi..
    You need to check this
    Regards
    PCmania
    Jul 08, 2009 | Whirlpool WGD5300S Dryer
    Glow coil lights...but gas valve seems to be stuck.....tests from here?
    If you are sure that your model is a Whirlpool LGR5636L gas dryer I can help you. But before we begin look inside the door on side of the door opening and send me (those numbers). Thanks, Sea Breeze seabreezehvac@yahoo.com
    May 10, 2009 | Whirlpool LGR5636L Gas Dryer
    Dryers Logo
    56 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
