Question about Emerson LC391EM3 39 in. LCD HDTV
My emerson lc391em3 has a red light and is plugged in but wont turn on when i press the button on the tv
SOURCE: EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Posted on Apr 29, 2008
dsacco86
  • 1077 Answers
SOURCE: my flat screen tv does not have a picture or
I've had the same problem with a 32" model LC320EM82S. All the Emerson TV ( no matter what size ) are having the same issue.
I'm sure with your TV, the green light is blinking before the TV automatically turns OFF. Basically, the TV is trying to power up the screen and has failed. Protection mode turns the TV OFF to prevent other parts from being damaged inside.
My solution for fixing my TV was replacing one bad inverter transformer of six on the Backlight Inverter/Power Board. Here is what my board looks like: 767c946.jpg
You can see the six inverter transformer on the bottom of the board. It's what supplies power to the screen. Your board may look similar. You can sometimes find a whole replacement board over the internet for a good price. Shopjimmy.com is a good place to start. Just start searching by your TV model number.
If you have some electronic experience, you can repair the board itself by finding a Service Manual over the internet for less than $20. It will have all the part numbers, schematics, and diagrams you need. I would investigate the inverter transformer for your problem.
I hope I helped you out with your problem.
Posted on Sep 04, 2009
  • 3 Answers
SOURCE: Emerson LC320EM1 flat TV will not turn on. Green
try turning off the power saverv feature
software problem ?
Posted on Jan 13, 2011
jdvillanueva
  • 2098 Answers
SOURCE: I have a 22'' emerson
Hi kellswty15,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board for your convenient, click this LINK. Double check the actual part no. of your board before ordering.
Also check if your unit is under warranty/extended warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Jul 21, 2011
SOURCE: EMERSON LC320EMX WHEN TURN ON GREEN LIGHT FLASHES THEN GOES TO RED
Sounds like capacitor/s failing on the power board. This is a common issue and there is lots of literature and even videos on how to perform the repair on web. A shop will charge upwards of $200 for this repair yet if you find the components and only have them change those; perhaps they will work with you on cost. GL!
Posted on Sep 12, 2012
My Emerson TV wont turn on
Could be an open internal fuse or power supply failure
Aug 03, 2017 | Emerson Televison & Video
I have a Emerson tv model LC391em3 ever time I turn on no sound until I unplug then plug in then I get sound
Main system control memory ic fault. Check and replace it
Contact any service technician. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Feb 22, 2017 | Emerson Televison & Video
No remote for Emerson # LE320EM3,how do you turn tv on.Has no power button
Look just inside the rear with a mirror. Sony hides them there as well.
EMERSON Replacement Remote Control for LE320EM3 ... - Amazon.ca
https://www.amazon.ca/Replacement-LE320EM3-LC501EM3.../dp/B00FKH6ME6
  1. Cached
EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3: Amazon.ca: Electronics.
EMERSON Replacement Remote Control for LE320EM3, LC501EM3 ...
https://www.amazon.com/Replacement-LE320EM3-LC501EM3.../B00FKH6ME6
  1. Cached
Find helpful customer reviews and review ratings for EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 ...
Amazon.com: Original New Remote Control / NH305UD: Home Audio ...
https://www.amazon.com/Original-New-Remote-Control-NH305UD/.../B015IFY96W
  1. Cached
Original Factory Remote - No need for programming it just works! Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, ...
Emerson LE320EM3 LE260EM3 Remote Control and Manual ' eBay
www.ebay.com > ... > TV, Video & Audio Accessories > Remote Controls
  1. Cached
EMERSON LE320EM3 LE260EM3 REMOTE CONTROL AND MANUAL in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Accessories ...
Remote Control for Emerson TV ' eBay
www.ebay.com/bhp/remote-control-for-emerson-tv
  1. Cached
  2. Similar
Original New Remote Control / NH305UD by Emerson. Supports these EMERSON Models: LC391EM3, LE190EM3, LE220EM3, LC501EM3, LE320EM3, ...
Emerson TV Remote Controls ' eBay
www.ebay.com > ... > Emerson TV Remote Controls
  1. Cached
www.newegg.com > ... > Audio / Video Accessories > Remote Support Inc
  1. Cached
  2. Similar
Buy EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3 with fast shipping and top-rated customer service.
Redi-Remote EMERSON Replacement Remote Control for ... - Sears
www.sears.com/redi-remote-emerson...remote-control...le320em3/p-SPM925361391...
  1. Cached
Aug 23, 2015 - EMERSON Replacement Remote Control for LE320EM3, LC501EM3, NH301UD, LE190EM3, LE220EM3. Emerson TV Remote Control. Emerson LE320EM3 Google Search
Nov 24, 2016 | Emerson Televison & Video
EmersOn TV has no picture when you turn it on, I noticed that the red light blinks 4 times after pressing on, I'm curious if that means something? Please help!
the 4 blinks are a error code means something wrong inside the tv
type your number and error code in google maybe point you in right direction
Jun 23, 2015 | Emerson Televison & Video
Lc391em3 manual
Main board fault. Contact any service technician.
Mar 30, 2014 | Emerson Televison & Video
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
May 21, 2013 | Emerson LC391EM3 39 in. LCD HDTV
Color line in emerson tv
if you have the original remote what you do is you keep the tv on and with the remote you press up and down on the remote controller... not the channel or vol buttons but the ones that control dvds... unplug and replug the tv in
Nov 15, 2012 | Emerson LC391EM3 39 in. LCD HDTV
Need codes to program a dishnet remote to a emerson tv
Turn on device you want to control (TV, VCR, DVD)
Press and hold the CODE SEARCH button until the red indicator light remains red, then release
Press the desired mode button (TV, VCR, DVD) and release
Press the POWER button slowly, but repeatedly
until device turns off. While doing this, the red indicator blinks then stays lit
Once the device turns off, press and release the Enter button to install code. The remote should be synced to the device.
Another view:
Someone on another board pointed out that with some newer models you do not need to press the CHANNEL UP button repeatedly. Rather, you press it only ONCE, and the device will cycle through all the code possibilities. When the TV turns off, it means that the proper code has been found. Immediately press the Enter button to install that proper code. This method (and no other) worked for me.
Jun 20, 2010 | Emerson LC320EM8 32 in. LCD TV
Emerson LC391EM3 39 in. LCD HDTV Logo
79 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
