Question about Coby MP-C7085 MP3 Player
How do i fix the button?
The button is stuck down and i can't turn it off
  • 11,896 Answers
Unscrew device, pull button cover off and clean it with rubbing alcohol and cotton balls, just don't get any on electronical side, just keypad side
Posted on Jan 28, 2009
My gotab 7 is stuck on the android loading screen how do you fix that
Turn off your gotab hold the volume up button and power button down at the same time. Then it should say recovery menu in red letters on the screen? Then press and hold just the power button again to hard reset the device I hope this helps?
Oct 05, 2014 | Aquachek Extra Strength Tylenol GoTabs
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Ht-2004 volume down button stuck, no sound
Remove button and maintenance work has extended the spring
Jan 25, 2014 | Audio Players & Recorders
Ipod touch volume control stuck
Just press and hold the lock button down until there's a slider that says "slide to turn off" (or similar). this will force your ipod to reboot. Once it shuts down, push and hold the lock button again until you see the apple logo. that should fix it.
Jan 29, 2012 | Apple Ipod Touch 4th Generation
Hp 3050 power button quit functioning; cannot press it down. Is this self reparable?
To fix the power button, which is stuck down or does not spring back up....remove the panel which has the all the buttons and the power button, the panel does not have any screws to remove, you got the pull it out from the lower side and move slowly towards the top. Once the panel is free, you will see that the power button is connected with a small plastic connector which would be broken, fix the broken piece or get a new piece and the problem is fixed........
Nov 19, 2011 | HP LaserJet 3050 All-In-One Printer
How do I get rid of osd lockout
Fix One:
Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Apr 12, 2011 | Packard Bell Computers & Internet
How do i unlock my osd
Hi There,
Please follow the below steps :
Fix 1 :
Fix 2:
Fix 3:
Fix 4:
Thank you
Enjoy and Cheers !!!!
Please click the YES option if this solution fixes your issue... :)
Nov 07, 2010 | Computers & Internet
Stuck on welcome screen
This means there is a button stck down!
1. Remove the batteries.
2. Push in, and massage each button to ensure that they are not stuck down.
3. Update the firmware.
4. Update the remote.
Fixed!
Jun 14, 2009 | Logitech Harmony 520 LCD Remote Control
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
Sansa E200R gets stuck in refresh when I turn it on
http://www.sansa.com/support/sansa_e200/faqs
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
If that does not fix it, please post a comment with an update to your problem.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Coby MP-C7085 MP3 Player Logo
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
