Question about Garden
My husqvarna 372 has a dinging sound coming from the drum.I hear when its at idle.I can hear it with the saw off if i turn the drum with my hand,i checked the clutch springs and they are good.The drum does have a little wiggle on the needle bearing.Any ideas
  • David riehle Jan 24, 2013
    Kelly are you talking about the needle bearing?
    Sergeant:
  • 322 Answers
The drum bearing probably needs to be replaced. The dinging you hear is the drum.
Posted on Jan 23, 2013
  • 13 Answers
SOURCE: needle bearing maintenance
use a plastic piston stop and the proper clutch removal toop. Try Baileys on line or Madsens saw shop for the removal tool. Must order for the specific model, but they are rather cheap.
Posted on Nov 02, 2008
  • 36 Answers
SOURCE: 345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Posted on Jan 06, 2009
  • 211 Answers
SOURCE: adjusting carb on husqvarna chain saw
Hi First turn them(H and L) clock wise until the end and then adjust.
high speed H=3/4 turn
lowspeed L=1 1/4 turn
idle speed T adjust accordingly
best regards savumihai71
Posted on Jan 19, 2009
steve_lima
  • 181 Answers
SOURCE: Husqvarna 357xp rim sprocket problem
there is a special tool to remove the clutch properly with out damage to the clutch or springs.it is so much easier to take it in some where and have the proper tool used.the tool is $45.00 to $65.00 to buy one.most dealer will only charge you a couple of bucks to remove it and install one for you,it only take a second to do.I,myself have made a couple of differant ones because chainsaw differ so much.let me know and maybe i can get you a picture of the one you need
Posted on Feb 11, 2009
steve_lima
  • 181 Answers
SOURCE: husqvarna chain saw clutch bearing removal
you need a specal tool to remove the clutch assy.it grabs the clutch assy. and you spin it reverse thread.most shops will only charge you a couple of bucks to remove and install it if you have the parts
Posted on Feb 23, 2009
I have a husqvarna 375xp chainsaw and I can't find any information on this chainsaw. Can someone please tell me how and where to find the information.
would say limited production edition
if its age is around 2013 they company started a new production plant
possible something in the carby tweeked ,longer bar ?
is it painted something other than orange ?
husqvarna didnt change their saws designs radically
even the chains and bars from most husqvarnas will fit
this user manual will cover your chain saw
365 SPECIAL 372 XP 372 XPG
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_EUenAPen/HUSO2010_EUenAPen__1153180-26.pdf
May 06, 2016 | Husqvarna Garden
Help husqvarna 372 chainsaw will not run
check with a husq.dealer,they had some crummy carbs that may need replaced not rebuilt
Mar 06, 2014 | Husqvarna Garden
LG Dryer dinging sound
Turn the drum by hand to see if it makes the noise.
Jul 17, 2013 | LG DLE2516 Electric Dryer
Instruction to remove and replace cage bearing on husqvarna 055 chainsaw.
I guess we are talking the bearing in the clutch drum, to replace this you need to remove the side cover nuts and remove the side cover/chainbrake, make sure the brake is de activated by pulling the hand guard fully back to the top handle before removing it, the clutch has a 15mm centre nut, jar the clutch off against the compression of the saw with a suitable socket and speed brace, if you have an impact wrench this will remove the clutch in seconds, the clutch is just spun onto the crank with a left hand thread, turn clockwise to remove, once off the drum and bearing will just come off the crank for replacment.
Oct 05, 2011 | Husqvarna Garden
I have a 455 rancher.I take very good care of my equipment but. the manual states to lube the clutch bearing.How can I do this with out tearing the clutch apart.It may also need special tools?Any help...
The passage in the operatore manual is the same in all mauals, it is taken from the pro saw manual, here you can grease the bearing through the end of the crank, you cannot do this on the 455, you do need to remove the clutch and drum, the reality is that the drum bearing is only turning if the saw is idling without the chain rotating, the crank then turns in the drum, unless you leave the saw idling for long periods of time ( this is bad practice ) the bearing is doing very little, there is normally plenty of oil flying around to lubricate it, to remove the cluch there is two cut a ways in the clutch spider, these are designed to take the screw driver from the combi wrench, with a suitable hammer jarr the clutch against the compression of the saw until it un spins from the crank ( left hand thread )
Jul 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
When saw is running it dies unless i undo the vented gas cap then the saw will keep going is there any other way on other than the gas cap for it to vent or help breath? on a 372 xp
The vent on the 372 is not in the cat, it is situated on the right hand rear side of the fuel tank, the early vent was a black pipe pressed into the tank with a white ( vion ) plug in it, this can be pulled out by screwing a self tapping screw into the middle of it and pulling out with a pair of pliers, the later breather is in the same place but consist of a green valve pressed into the tank, it then has a black pipe conected to it which comes up into the crankcase and sits onto a nipple under the air filter, this can be pulled out with a pair of pliers and replaced, the later breather is very prone to blocking, due to CE law and gas escape from fuel tanks the breather is very fine.
Jan 25, 2011 | Husqvarna Operator's Manual 365 372xp ...
I have the same problem with my 350 Husqvarna chain saw. I took the saw to a licensed Husqvarna Dealer. The dealer said that there was noting wrong with the saw. The dealer did clean the carb. I brought...
The temperature is not that different. Is there a fair change in altitude between the dealer and where you live? The jet screws have 'D' heads to prevent owner tampering--how did you adjust them? You need to allow the engine to warm up before pulling the throttle. Make sure the fuel mix is fresh and mixed 50:1 with synthetic chain saw oil--be sure to shake the container thoroughly just before filling the tank each time to prevent oil starvation. It has to be the manufacturer's problem because it is under warranty. It sounds like the jet screws are set fairly lean. Ask the dealer if you can buy the special 'D' head screwdriver to make your own adjustments. Hope this helps!
Jan 09, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
On the husqvarna se266 carborater, what is the low and high screw settings or how many turns is the screws supposed to be at?
Initial setting for a Husqvarna; "H" and "L" screws at 1 turn CCW form lightly seated. Then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Feb 22, 2010 | Garden
Husqvarna 385
Sounds like dirty carberator or carb needs adjustment. How is the spark plug?
Jun 22, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
