Question about Polaroid Televison & Video
Why is my picture getting darker?
My picture is gradually getting darker.
    Top Expert:
  • Polaroid Master
  • 74,468 Answers
If CCFL lamps are weak, this might happen. Check the control voltage comes to backlight inverter board from the main board too. It should vary according to increase in brightness.
Posted on Jan 24, 2013
PICTURE WENT OUT, FIRST FLUTTERED , GRADUALLY GOT DARKER, FINALY WENT OUT. IF I TURN IT OFF FRO A MOMENT THEN ON , PICTURE IS THERE BUT DOSENT LAST LONG
The ballast board is bad. This board is where the wires from the lamp connect to. It controls the lamp. It needs to be replaced. You can get one here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 16, 2016 | Televison & Video
Sharp LC-65d64u. Does this tv use a lamp that can be replaced
Refer its user manual and see there is any description about lamp repalcement. If yes, there is a lamp. If not there is no lamp. OK?
Gopakumar Gopalan Google
Feb 17, 2014 | Sharp Aquos Televison & Video
Picture is really dark. I can see outlines of picture, but no color. I turned up brightness all the way.
Hi, Did the TV go darker gradually or did it happen all of a sudden? Sounds like the tube went!
You Can do a test or two?
Sep 04, 2011 | Panasonic PV-C2540 25 in. Combo
Picture on tv is dark panasonic mod pt47wx42
IT may be if the set has not been "serviced" in a while a cleaning issue. If picture got gradually darker try something easy first.
Unplug set and remove back cover.
Locate the three large black lens in set based on model number, use either a lens cloth or a paper towel with glass cleaner sprayed on it and clean all three lens.
The lens are the light source for your picture and if dusty the picture will be darker and duller looking than it should be.
If this is your problem it is a good idea to clean the lens at least one time a year.
Let me know if it works OR IF YOU HAVE QUESTIONS.
SD TECH
Jan 12, 2011 | Panasonic PT-47WX42 47" Rear Projection...
Problem with the Philips Magnavox 9P6034C 60 in. Rear Projection Television, had TV for 16 years. Picture gradually got darker and less clairity
the projection tubes do wear out over time and there is no fix but to replace them. you might first check to make sure the lenses and mirror are clean, do not use compressed air to clean as you may force dust between the lenses. if the picture is darker at the edges or a different hue then the coolant is likely contaminated and needs changed
Dec 15, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture gradually getting darker
Don't know what kind of TV it is, but if it is a DLP you are probably in need of a new Lamp
Jul 05, 2009 | Televison & Video
Dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Jan 15, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Picture gradually going dark
turn the screen up a little on the flyback..
Dec 16, 2008 | Toshiba 50A61 50" Rear Projection...
I have a 10 to 12 year old Zenith SY2772 tv. The picture is getting gradually darker and darker, so that it is very hard to see what is going on in scenes that are dark to begin with. I assume that it is...
Yes it could be other things, but to be honest, I wouldn't waste time or money on a set that old. If the picture was perfect and something else went bad, perhaps a small investment would be worth it, but with your description, I'd pass.
Time for a new set.
Dan
Jul 24, 2008 | Televison & Video
the lamps have to come out. the fluid has to be sucked out from the bottem.
Jan 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
